180 t-stat and fan switch
Old Oct 10, 2004 | 08:29 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
where on the enternet can i buy a 180 t-stat and a fan switch that turns on the fan at a lower temp
Old Oct 10, 2004 | 09:15 AM
oil pan 4's Avatar
Car: 89 Firebird
Summit has them in there cooling section.
Old Oct 10, 2004 | 09:22 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
more stuff
JET-60600 will this switch work on my firebird. also when i get the 180 t-stat and a switch can i use a hypertech street runner aftermarket chip? if not which after market chip should i go with thes cooling mods super chips, fastchips, hypertech, or jet?
Old Oct 10, 2004 | 09:27 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
jet chip
will this chip work fine with my applications? Stage 2 #19117S
Old Oct 10, 2004 | 12:16 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Do you need to change the ecm chip when going with a 180 stat and a faster opening fan switch?
Old Oct 10, 2004 | 01:23 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
First off, 3.1s don't have an external fan switch. The fan is controlled by the ECU. Second, all of the cookie cutter aftermarket chips are an utter waste of money. They add a tad bit of fuel and a tad bit of spark advance at WOT. Sadly, an AFPR and mild timing adjustment at the distributor will generally reap better results. Nothing wrong with the 180 degree thermostat, though.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
