wild reading
Old Oct 17, 2004 | 07:31 PM
WRENCHMAN's Avatar
Car: 86 fb
Engine: 2800
wild reading
ok, ive got a idle tps reading of .4
and a WOT reading @ 8.1
tell me what's up guys
(this is 2 different tps's)
Old Oct 17, 2004 | 08:51 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
check your multimeter... I find it difficult to believe a 5v reference line is generating an 8v signal
Old Oct 18, 2004 | 10:54 PM
WRENCHMAN's Avatar
Car: 86 fb
Engine: 2800
well, what setting should i have the volt meter set to then?
it's brand new.
Old Oct 19, 2004 | 03:45 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Kinda depends on what settings are available. On most digital multimeters, you would have it set to 20v DC. Analog, could be 10v DC. The idea, though, is to set it to the setting that's the closest higher setting to what you intend to read.. i.e. if you have a 10v, 20v, and 50v setting, and you want to read a 12v battery, set it to 20v.
For a quick diagnosis to ensure the multimeter isn't defective on this note, go ahead and get the voltage of your battery after the car's been sitting for 30 minutes (no doors open, no lights on, radar detector off, etc), and then check it with the car idling, and post the results.
The only reason I question the multimeter here is again, the signal line the TPS works off of is a 5V line. If it's actually getting 8v or more, something is very very wrong (short or impending ECU doom)
Old Oct 19, 2004 | 08:56 AM
WRENCHMAN's Avatar
Car: 86 fb
Engine: 2800
uh... ok ill tell you right now, i have it set to 200v setting..... cuz thats the only one that was getting an idle reading that was at .4
(the smallest settting) but i won't have a chance to fool with it again till friday or saterday
thanks for the input.....i hope that there is not ecm impending doom tho... ive got enough problems with that car....
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
sandman92084
Sep 12, 2015 10:27 PM
pacoelrapido
Sep 11, 2015 02:41 PM
