code 32 still?
Old Oct 22, 2004 | 03:17 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
code 32 still?
Why am i still getting this code, the only thing i can think of is the egr valve, but it moves up and down with now problem, so i don't think thats it, new vac saliod on it $100. Not cheap Any ideas? Thanks
Old Oct 22, 2004 | 03:44 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Check the vaccum hose condition and routing. I wwas getting that on my 85 and the one hose pooped out by the TB. It wasn't even the one for the egr
Old Oct 22, 2004 | 03:46 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Thanks man, i will double check it, i know all the vac hoses are pretty new, but i will diff check, thanks again
Old Oct 22, 2004 | 05:38 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
do you have a haynes manual it shows you a few ways to check it to make sure its the egr
Old Oct 23, 2004 | 09:52 AM
gunfixr's Avatar
Car: 88 camaro
Engine: 2.8 v6
Had the same problem.
It's not the EGR valve. Instead of yanking out your hair and going bankrupt at the auto parts store, Go to a boneyard and get yourself another vacuum switch and another EGR solenoid out of a scrapped Firebird or Camaro.
For some reason these components like to crap out more frequently than other emission components.
Old Oct 24, 2004 | 04:09 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Both items you mention are new $96.54
Old Oct 24, 2004 | 04:13 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
yeah but a boneyard it would be less then 20 bucks, couldn't hurt to try
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
