Going to run new fuel lines
Old Oct 23, 2004 | 11:42 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
while the car on jacks & swapping trany's. Will THIS work good for our fuel lines, or just get the steel ones & bend as neccessary?
Old Oct 27, 2004 | 02:58 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Fuel Lines
You might run into trouble making the rubber ends that attach by the fuel tank. Inline tube sells new steel tubes for the V8. They probably are the same as for the V6. Measure to find out, or contact them.
http://www.inlinetube.com/CC-CAT-08.htm
Old Oct 27, 2004 | 06:44 AM
oil pan 4's Avatar
Car: 89 Firebird
Al line is good it is light. I woudl go with 1/4'' for a V6.
The tank on a TPI V8's and MPIF V6's are the same when I checked the junk yard back when I thought I had a hole in my tank (stupid leaking fuel lines).
Old Oct 28, 2004 | 05:33 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
Is it really a pain in the butt swapping gas tanks? I got 1 hole in the top of mine because of me being a moron...
Old Oct 28, 2004 | 01:08 PM
Engine: 5.7 / 7.4
in the top, huh?
Old Oct 29, 2004 | 11:27 PM
KED85's Avatar
in the top, huh?
I AGREE HUH?
Beyond that
find the threads about swapping in a fuel pump.
Basically ya "drop down exhaust"
Lower axle (detatch shocks) and twist tank out.
HARDEST PART IS
When ya drop or INSERT BACK IN TANK
MAKE SURE about your filler neck!
BE GENTLE ON THAT POINT it is "fragile".
Ya wanna stick in neck into tank filler spot, then twist & rotate upward, seat tank back into car.
Yes it is a project.
Plan on doing a new fuel pump at same time, as you'll not want to do this again. Look at it as a blessing.
You'll be getting a good tank & new pump done all same time
PS BIG TIP
FIND a post 1990 tank
WHY BETTER INTERNAL BAFFLES ARE BUILT IN SO WHEN YA GOING & DOING EXTREME "G"s FORCES (turns) THE GAS WON'T LEAVE THE FUEL PICK UP!
I'd rather hear ya scored a cheap post 1990 tank & ya have the project done & ya leak free.
Gas leaking by exhaust system is not a wise thing to drive!
OR MAKE SURE your "putting hole in tank" is a good story so we all have a good laugh!
Old Oct 29, 2004 | 11:31 PM
Engine: 5.7 / 7.4
some 4th gen tanks are plastic too
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
