degrease\wash undercarriage ?'s
Old Nov 3, 2004 | 01:22 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
Don’t know where to post this, since I have a stock v6 (+ MSD ignition\blaster coil)…
My trans is leaking. When I get under my car it is so dirty, I can’t see where the leak actually is. How can I degrease, wash the undercarriage without damaging\hurting anything? What precautions do I need to take? Does anything need to be covered? And since I’m doing that, I may as well do the engine bay too. Same questions for that too.
Thanks for the help!
Old Nov 3, 2004 | 04:55 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I would just go down there with some rags wipe everything down it wil get all the grime off. Then if you want go to a wash it your self car wash and spray under the car with there pressure hose. While your at it midas well clean your engine.
Old Nov 3, 2004 | 05:39 PM
CDN_87IROC's Avatar
My transmission is out ... but I went from this ...
Old Nov 3, 2004 | 05:40 PM
CDN_87IROC's Avatar
to this ... with oven cleaner.
Old Nov 4, 2004 | 07:37 AM
azcamaro's Avatar
Thanks for the replies!
What a great idea.
Old Nov 4, 2004 | 11:22 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Yup, that or brakecleaner. That's how I did mine. Follow it up with some gloss black enamel
Old Nov 4, 2004 | 11:36 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
I would highly suggest using black Epoxy paint (Appliance paint) It is much more durable for the undercarraige.
Also, Easyoff oven cleaner will remove anodizing so use caution on anything anodized.
Old Nov 5, 2004 | 12:38 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Oven cleaner works good. Though it can and will eat paint. Its great for striping clear coat off aluminum.
Krylon sell a farm equipment paint in a spray can that is very durable.
Old Nov 5, 2004 | 10:14 AM
azcamaro's Avatar
where is this sold? I've never heard of it.
Old Nov 5, 2004 | 02:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Seen it at walmart n andersons. Trying to find krylon fusion. Seams people have fusion. but only carry blue green n black and don't bother with the other 18 colors???
Old Nov 13, 2004 | 03:57 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
oven cleaner works the best, then use brake cleaner for those really tough hard to reach areas
Old Nov 14, 2004 | 04:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oven cleaner takes off the undercoating?? Cool. I used Eastwood's "UnderGone" undercoat removal spray; it worked pretty damn good, but oven cleaner is easier to get!
If you've got an automatic trans (not sure about manual transmissions but I think the same applies), they've got a plastic vent tube at the very top of the trans case- about where your shifter stick is. You shouldn't get water in that.
The axle also has a plastic vent tube, sticking straight up towards the sky, out of the "front side" of the diff case on the passenger side. You don't want water in there either, but it's got a nifty little cap on it to prevent splash.
That's one of the many reasons you don't want a flood car... water can get into the rear axle and transmission from their case vents.
I can't stand working on filthy oil dripping sludge cars... especially since I'm used to my "bone dry" engine bay. Yick.
Old Nov 14, 2004 | 04:40 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
oven cleaner strips its great, and its cheap.
thats why ive used it
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
neilb
Sep 15, 2015 05:06 PM
Ragtop Man
Sep 12, 2015 12:23 AM
blackandblue02
Sep 10, 2015 08:19 PM
