Alternator upgrade and poly suspension
Old Nov 17, 2004 | 06:11 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
I think i might need a new alt soon, is there one that is a direct replacement and puts out more amps than stock alternator? And I plan on doing a motor swap this weekend, I think it would be good time to swap tranny and motor mounts with poly ones. What do I need to buy for the motor mounts? Are they two piece? Will I need to do major surgery to get them apart?
Old Nov 17, 2004 | 06:14 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
Re: Alternator upgrade and poly suspension
best place for an alternator is edmonds starters in burnaby , got mine from them, they will build one for any application.
Old Nov 17, 2004 | 06:15 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
oh and any plans for that 2.8? i'm looking around for one to rebuild.
Old Nov 17, 2004 | 06:56 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Autozone 108 amp upgrade alt $60
I run extra 55watt running lights and around 1500watts in stereo and have plenty of juice.
Old Nov 17, 2004 | 11:41 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Stock alt on an "87 and up is 105 amps already. I don't know about the pre-'87 cars though, I don't own one.
I run a 140amp V8 TPI alt from Powermaster. Its a homemade custom bracket.
Old Nov 19, 2004 | 05:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
85-86 got a 108 amp alternator with a/c, I believe cars without a/c got 78 amp ones.
Not sure about 82-84 ...
Old Nov 24, 2004 | 03:39 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Give it 6mo and it will die. A good one might last a year. I got a lifetime one from Autozone for this very reason. The remans suck! I have had most not put out enough to keep up with the car. And my stereo is not all that. Have even had 2 completely disinegrade inside and granade. One locked up so bad the fan/pulley quit turning. The belt then turned it and zipped off the nut. I ahd to go out in traffic and chase done my parts so I could return it with everything.
With some crazy swip swapping, I ended up with 2 alternators. Thanks to Autozone and the junkyard. My autozone one died. Found a Autozone one on a f-body in a yard and got it. Not trying to get something for nothing mind you. Just needed a stock case to turn in with the dead alt. I had painted and polished mine. Autozone took my guts with the other case no prob. Got a new Atl for them. The Spare. Took the junkyard one with the now chromed case to a rebuilder and he totally rebuilt it. Not just replacing what was bad, but replacing all bearings and such!
Moral...find a reputable rebuild shop and get tehm to rebuild it. They can probably get you more amps in the same case!
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
