quick question
Old Nov 18, 2004 | 08:52 AM
Silver_IROC_87's Avatar
quick question
i wanted to throw in a blazer 4.3 liter instead of a 2.8...and wondered if its possible to install a MPFI on it....just curious
Old Nov 18, 2004 | 09:30 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
No. the 2.8 is a 60 degree motor and the 4.3 is exxentially a SBC (90 degree). To use the MPFI, you would need alot of fabrication.
Old Nov 18, 2004 | 11:20 AM
Camaro Project's Avatar
Car: Chevy
Engine: Largest Factory V6 on Earth
Transmission: 700R4 w/ Trans Cooler
I've had the same idea for a little while now. As MDV6 said, it would require a lot of fab, if it is even possible. I'm not sure what year the 4.3 is, but if it's a TBI, you can probably put the CPI system on there. I believe you would need a different ECM and a few other things. I've heard the real restriction are the heads if you don't have the Vortecs. I know you can swap them over as well, but again, I don't know the specifics. Go to a couple of S-10 sites. They'll be able to help you out.
Old Nov 18, 2004 | 03:29 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
for the amount of work a 4.3 is its better just to put in a 350, because the 4.3 is basically a 350 without 2 cylinders
Old Nov 19, 2004 | 10:27 AM
Car: Chevy
From what I hear, the only extra work required is relocating the motor mounts. And there are additional advantages to using a 4.3. Less weight, better weight distribution, gas mileage--questionable, sleepyness---It looks exactly like a 2.8--------at least the S-10 2.8s---- and you'd have a unique setup. One of the biggest problems is aftermarket mods. There isn't a lot offered for 4.3s.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
