Air intake harness connections..where?!!
Old Nov 19, 2004 | 07:28 AM
watafo's Avatar
Car: Chevy Camaro Berlinetta
Engine: V6 2.8L
Transmission: Automatic
Hey guys, I just need some help to figure how I have to connect this two vacuum lines in the air intake harness. Are they only 2? 1 is going to the fuel regulator and the other is going to the ignition coil. Please, tell me which one is for each component.
Attached Thumbnails Air intake harness connections..where?!!-airintake001.jpg
Old Nov 19, 2004 | 08:18 AM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
There should only be two vacumme lines going to that, I think the third one to the left is not ment for a vacumme line, maybe someone can assist me in that? hope this helps
Old Nov 19, 2004 | 10:10 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
The big one on the right is the one on my car that isn't used. The other two don't matter which way you hook them up since they share a common opening in the throttle body cavity. Just route the vacuum lines so they don't cross and rub.
Old Nov 26, 2004 | 08:41 PM
watafo's Avatar
Engine: V6 2.8L
Got it, thanks for all guys. Yeah, you are right man, the third one on the right is useless.
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
