3.5L V6RSR begins
Old Nov 25, 2004 | 10:19 AM
  #51
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Originally posted by Jerriko 3.4
What difference does the 3" pipe make if it bottlenecks back down to 2 1/4" behind the muffler? I think 3" is too big if the WHOLE exhaust is 3" in diameter, not part of it.
he's talking about duals out of the muffler. i have dual 2.5s out of my flowmaster.
Old Nov 25, 2004 | 11:42 AM
  #52
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Originally posted by Pillsbry10
yeah i disagree on the 3" being to big as well...im running PF&E headers into 2 1/4 tubing into a y pipe 3 inch to the muffler and then 2 1/4 back out of the muffler....seems to run very well, looks as though my tq numbers jumped a lot from it
Let me point out in saying that your PF&E y-pipe has a merged collector with a 2 1/2" exit- so why go into a 3" pipe from that point?
3" is not going to help flow if there is a prior section of pipe (hotter gases also I might add because it is closer to the engine) that designate 2 1/2" dia of flow before it even reaches the 3" section.
Now once it does reach the 3" section, the hotter gases cool and slow down because they are first off further from the engine with every inch, and seciondly you are slowing them up more by increasing the pipe diameter. All of the cooler slown down air now has to be PUSHED all the way out through the muffler and out the tailpipes. It takes pressure to push those gases and this robs flow out of the moptr into the headers, thus hindering flow into the motor.
Old Nov 25, 2004 | 12:40 PM
  #53
Car: 91 Camaro
yea, i agree definately that if you have a smaller pipe anywhere in there, there's no reason to go bigger after that.
ZZ3Astro
Aug 13, 2019 12:57 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
starliner
Feb 9, 2016 08:18 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Marc Brown
Sep 28, 2015 01:40 PM
