Help?
Old Dec 10, 2004 | 08:04 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Help?
I don't know if I should post this here but I have no clue and I know you guys can help me out. I need a set of GM steel wheels for winter tires for my car. Now i found some on a an old caprice. But I was told the lug pattern is different, what cars would have the same lug pattern? I don't think v-8 or V-6 matters. Thanks
Old Dec 12, 2004 | 06:41 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Umm I would call a local rim shop...they should have a way to tell you what the stock offset and lug pattern is on yours adn the caprice
Old Dec 12, 2004 | 06:42 PM
redraif's Avatar
Worst case...call the seller...have him/her measure from the center of the bolt hole to the center of the other bolt hole, both in a circle pattern & in the imaginary star pattern used to bolt up 5 lug wheels
Old Dec 12, 2004 | 08:48 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Thanks guys, I'm almost postive its a 5 inch instead of a 4 3/4. Thanks guys
