Jerriko 3.4! :)
Old Dec 9, 2004 | 01:57 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Jerriko 3.4! :)
Hey man, just noticed your sig - 13.42 @ 102mph? Is this the 100shot + 3.4 you've got? If so, friggen' awesome man!!
Old Dec 9, 2004 | 04:32 PM
oil pan 4's Avatar
Car: 89 Firebird
Check out his ebay store, you can buy all the stuff he dosen't want.
I got a WS6 frount sway bar :rockon: .
Old Dec 9, 2004 | 06:30 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Yup. I was first to know, I'm special I'd like to be able to match his time, but I doubt it'll ahppen without swappin on my new heads, and doing somthing about our ****ty intake manifolds.
Old Dec 9, 2004 | 08:51 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'd love to have a slightly cleaned up version of his intake.
I know prototypes are known to look a bit rough. But now that hes done one, the next/others could look better.
Old Dec 9, 2004 | 09:42 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
dale, who's intake? i think i missed somethin, somewhere.
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
Yes, I agree. I am working on another intake now. It sits about 3" higher and eliminates the nasty curves.
Yes, the time was on a 100 shot and that was with the slipping clutch so it does have more in it.
Last, I sell 3rd gen parts for those of you that don't already know. I tried to become a sponsor here but I was turned down. The only thing that the powers that be suggested was to put it in my sig and post alot. Right now, I am parting out a 92 Firebird w/ 3.1L V6 and an 89 Formula with a TBI 305.
Thanks for the support,
Jim
Old Dec 9, 2004 | 09:44 PM
FbodTrek's Avatar
Can I have the old one when your done with the next one?
Car: 91 Camaro
any pics or info available on this thing? hopefully i'll get some time to get back on my intake next week!
Old Dec 9, 2004 | 09:47 PM
Engine: 3.4L 207 V6
It will sit 3" higher and it will not be as wide so I will be able to pull the valve covers without any problems. If I had to compare it to anything, it will more resemble the runners of a TPI setup. I was considering doing that the first time, but it would have been more work (and money). It will be going on the 2nd version of my 3.4L.
Old Dec 9, 2004 | 09:49 PM
Car: 91 Camaro
awesome, what kind of gains did you see with the one that you have? preferably numbers from N/A but i know that you might not have those.
Old Dec 9, 2004 | 09:53 PM
Engine: 3.4L 207 V6
I don't have any yet to date. I was going to dyno the different intakes after I finish the second one. N/A and n2o.
One a second note, I have a December promotion going on for members of firebirdv6.com, that I will also extend to members of this board:
December promotional offer
Please don't delete me!:lala:
Old Dec 9, 2004 | 11:29 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
I keep preaching to everyone that the stock intake is what is really hurting us. This is another proof. Great #'s Jerriko
Old Dec 10, 2004 | 01:18 AM
Engine: 3.4L 207 V6
Thanks.
Old Dec 10, 2004 | 10:15 AM
Doward's Avatar
Yes, the stock intake is a major performance killer. The only reason I did the turbo over the intake first, is because I figured the turbo would yield more power than the intake
Old Dec 10, 2004 | 11:58 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Ditto. I think we won out on that bet too
Old Dec 10, 2004 | 12:08 PM
FbodTrek's Avatar
All I know is, If someone builds one that fits under the hood, is reasonably priced and can be used in place of the stocker, they should market it. That stock unit has a runer cross section of about an inch...needless to say it's not tailored for a 3.1, and darn sure doesn't have the volume to support a 3.4 at higher RPM.
Old Dec 10, 2004 | 12:41 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The only other problem is those who run STB over top of the intake. There isn't much room with a stocker one and a STB.
Though I have always been for products that function better then they fit. If ya had to run a cowl hood for a decent flowing intake, then so be it.
Old Dec 10, 2004 | 01:50 PM
Dale's Avatar
Engine: 350 S-TPI
Good point gumby.
I'm not seeing as how 3" higher would fit under the hood though?
Wish somehow the 3.4 intake would fit around the distrib.
Old Dec 10, 2004 | 03:08 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well you know what I mean. Even if you have to fab a whole new hood, so be it.
I like them big fart can intakes.
Old Dec 10, 2004 | 04:11 PM
Engine: 3.4L 207 V6
Good point gumby.
I have a 4" fiberglass cowl hood on the car right now.
Old Dec 10, 2004 | 05:43 PM
FbodTrek's Avatar
Good point gumby.
That 3.4 Intake isn't much better than the stocker. I looked into modifying one, it's mre effective to use ours.
Old Dec 10, 2004 | 06:39 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
quick question will a strut tower brace fit after a 3.4 is put in? i have one now on it but i had to modify it for it to fit with my hood, wonder if the engine will cause another problem?
i would defintily by a reasonably priced intake if someone could make one
Old Dec 10, 2004 | 06:44 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Not sure if Id have the never to post a pic after it was done but wonder what could be done with some 5-6in PVC pipe.
Two pieces 6-8 in long. End caps on one end, a 2 into 1 Y on the other end. Make some sort of adapter for the TB to mount on to the end of the Y.
Course a stock hood aint gonna shut. Would have to run hoodless for testing.
Old Dec 12, 2004 | 06:56 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
So no one had really said...does anyone think that if I got the blasted stock plenum, runners, & lower runners extrude honed, that I would find any signifigant gain? Also the box style I have seen some make here would reduce torque numbers!? The stock plenum has runner walls inside. Also, I like the looks of our stockers and was trying to keep the more surprise factor. Look under the hood see stock looking "Prettied up" engine...but dyno numbers and 1/4 say different...effect @ shows! PLus I worry about clearing the STB as well!
Old Dec 12, 2004 | 07:01 PM
redraif's Avatar
Jim
GFX or no...I'm looking for a base modle rear bumper w/o gfx...basically like the older rear bumpers, but w/o the darn bumper inserts!
Old Dec 12, 2004 | 07:04 PM
redraif's Avatar
It will fit. Dimentionally the 3.4 block is the same... I'm running the BMR brace...only rubbing, I believe, because the Suncoast hood a little less clearance then stock.
Old Dec 12, 2004 | 07:11 PM
FbodTrek's Avatar
If I Can pick up say 10Hp across the board with an intake that won't fit a STB, then I can certainly do without one. I don't have one as is, mainly because I can pull hard enough around the corners as is. I'd ratehr be fast than corner better
Old Dec 12, 2004 | 08:55 PM
Engine: 3.4L 207 V6
Yes, definitely agreed.
Engine: 3.4L 207 V6
Sorry, I sold my last one of those types last week.
Jim
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
92projectcamaro
Sep 29, 2015 07:07 PM
92projectcamaro
Aug 6, 2015 01:20 PM
87CamaroLT
Apr 23, 2001 09:32 PM
