Hard start sometimes
Old Dec 11, 2004 | 08:23 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
What would cause the engine to start about instantly most of the time, and then every once in a while need to be cranked forever (well, about 5-8 seconds) to start?
The starter sounds the same to me every time, but could this be caused by a bad starter? I'm pretty sure mine's on its way out.
Old Dec 11, 2004 | 08:40 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Mine also seemes to do that sometimes, i highly doubt its the starter if its spinning the same speed each time. It only does this in the morning when i first start it, weird!
Old Dec 11, 2004 | 08:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
When does the fuel pump prime???
A faulty or bad fuel relay will make the car reverts to the oil psi switch. and not till 7psi will the pump prime. Fuel pressure doesn't hold forever or long. but sometime you have enough fuel to fire right off or you gotta crank it a min to get oil psi, to get fuel psi.
my system is faulty. New relay n stuff. Still don't prime the pump till I hit 7 psi. and so I leave it that way. Its not that big a deal and just means you got some oil flowing before it starts. Not really a bad idea.
Old Dec 11, 2004 | 09:03 PM
where is this fuel relay stuff, cuz I will also get a code 42 about once every couple weeks
Old Dec 11, 2004 | 10:36 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
on the right side of the brake booster, coouple of small black boxes of sorts. one fo for the ac in one for the fuel relay.
not sure right now which is which. I changed em both with no results.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
