Fuel Injectors Didn't spray Fuel
Old Dec 19, 2004 | 06:08 PM
JavaDude's Avatar
Car: 91 Camaro
Engine: V6 3.1 L
I have 91 Camaro 3.1 L V6 FI that won't start.
Fuel pump works ok. Fuel Pressure on intake is 45 psi.Cheked FI wires, they all get the voltage.If I spray Carb Cleaner to TB it will start. I need some helps.....Thanks
Old Dec 19, 2004 | 06:37 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Could goto a U pull it junk yard and get a used set of injectors to try. $10 maybe.
I find its best to pull what you need and then ask. Don't say what you need ahead of time just go look and find it. Make a pile of crap on the ground and say can I get this stuff for $20??? The answer is yes 99.9% of the time.
Someone else will need to chime in on which ones but you can steal injectors from many brands of cars. even fords.
Old Dec 19, 2004 | 11:13 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
go down to the parts store and buy what's called a noid light, you plug it in instead of the injector and crank the engine.
2 things could be happening, you could be getting no RPM signal to the computer(bad ignition module probably, they go bad all the time), or you could be in clear-flood mode. Make sure that the the signal voltage going to the ECM isn't close to 5 volts.
My best advice would be to take the ignition module out and take it down to AutoZone and have them test it. That's what i think it is.
BTW, do you get spark?
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
