Are these the same?
Old Dec 20, 2004 | 06:10 AM
oil pan 4's Avatar
Car: 89 Firebird
Are these the same?
I have been looking at V6 motor mounts.
If I could I would like to get newer ones, 3.4's. The rubber busings look like a bitch to get out and if I get all most 20 year old used mounts the rubber will be crap. Used 3.4's look a lot better.
Not to worried about geting the old busings out, I can just burn them out with a torch, does any one know If I would have a problem installing new ones? Use some KY or oil to help slip them in?
Are the mounts (to the frame) the same for 2.8 as later 3.4 camaros?
Now the V8 stuck with the same mounts from 82- through the LT1 years. Did V6 do the same?
I will find a pic for those of you that know all to well what a 2.8 mount looks like.
Old Dec 20, 2004 | 06:18 AM
oil pan 4's Avatar
Car: 89 Firebird
Pic... k-member side of motor mount.
Attached Thumbnails Are these the same?-3.4-k-member-side
Old Dec 20, 2004 | 09:22 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
autozone.com says 91 and 94 take same mount.
No poly one listed. I belive WAY down on dowards list was a conversion of using v8 poly mounts, and custom brackets to mount a v6
Old Dec 20, 2004 | 09:55 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Yes, that is correct on the Poly motor mounts.
Old Dec 21, 2004 | 12:29 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
I assure you, the mounts on a 3.4 are COMPLETELY different from a 2.8L/3.1L. I have 3 pairs lying around, they have different geometry than the ones for the 3rdgens. the mounts on the K-member are different as well. I'd take pictures, but my Cmaera moved out of my house (Sonar).
