View Poll Results: Should the turbo kit come with an adapter and run the '730 ECU?
Yes! The '730 is more powerful, and much better for boost!
83.33%
No! I don't want to pay the extra $180ish, and I'd rather have the older MAF computer!
0%
Optional. I mean, the MAF DOES run low boost well... sure, the '730 is SD, and is MUCH better under boost, but who cares?
16.67%
Voters: 12. You may not vote on this poll
Ok, guys, tell me how you want this!
Old Dec 31, 2004 | 10:35 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I just scored a '730 ecu + pigtail for dirt cheap.
Look to the poll.
Old Dec 31, 2004 | 12:42 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I'll abstain from the poll, for obvious reasons, but I am a MAF beleiver
Old Dec 31, 2004 | 12:59 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i sat leave it optional
Old Dec 31, 2004 | 01:13 PM
Doward's Avatar
I may just do that... or offer it seperately.
The problem with maf, is part throttle boost is much harder to control the fuel/timing, than it is with SD.
Old Dec 31, 2004 | 01:22 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
'730= 3.1v6 90-92?? if so then yes!
Old Dec 31, 2004 | 01:25 PM
Doward's Avatar
Yes. It'll come with the '730 ecu, re-programmed for boost, and a 2 bar MAP sensor.
Old Dec 31, 2004 | 02:03 PM
RedTtop5spd's Avatar
Car: 99 SS
Will there be an easy conversion setup for us '85 guys who currently have the b*stard child ecm?
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
What if we already have a 730?
Old Dec 31, 2004 | 02:30 PM
Doward's Avatar
Even if you already have a '730, you'll need my modified one. Now, if one were to email me, and I was certain they had the skills needed to modify their own, I wouldn't have a problem with that.
Keep in mind, this is only $150-$180 difference in the kit.
The bastard child '85? I'd like to find a pinout... if it is the same as the '302, then YES, it will work!
Old Dec 31, 2004 | 03:23 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
I have no idea what were talking about but YAY :yourock: :hail: :lala:
Old Dec 31, 2004 | 03:37 PM
Car: 99 SS
The 85's had an ecm all of their own. Different pinout than the 302.
Old Dec 31, 2004 | 04:36 PM
Engine: 5.7 / 7.4
The 86 ecm I have hooked up w/the 85 harness. I just swapped proms.
Old Dec 31, 2004 | 05:49 PM
Doward's Avatar
Sounds to me like the '85s will work with the '730 swap, too!
Old Dec 31, 2004 | 06:57 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I'll vote for "free turbo's for everyone."
Old Dec 31, 2004 | 07:35 PM
Dale's Avatar
Engine: 350 S-TPI
Doward, I know you gotta run a major modded one to run boost.
I was just trying to be a smart a$$
Old Dec 31, 2004 | 09:37 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
ya know, for the amount we'd already be paying for this kit (not that its a ton) that lil bit isnt that much more, just go for it doward!!!!!!!!!!!!!!!!
Old Dec 31, 2004 | 09:46 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Umm, what ECM does my 91 have? I know it's a MAP system, but my ECM's been replaced and has a dephi remanufactured number on it.
Old Dec 31, 2004 | 11:20 PM
Doward's Avatar
It should be a 730. Won't matter, as you still have the correct engine harness, and will be using the Turbo 730
Old Jan 1, 2005 | 11:50 AM
Car: 99 SS
Thanks. I've been looking for that info for a long time. Good to know. Now I need to go to the junk yard and get me a newer ecm and prom. The 85's are really slow compared to the 86's.
Old Jan 19, 2005 | 03:56 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
anyone know how high of boost we can expect to use on our stock 3.1 and not blow a gasket... plus how long will my freshly-rebuilt motor last on this kit??
Old Jan 19, 2005 | 05:00 PM
Doward's Avatar
Couldn't say. I basically did a re-ring on a 75k mile motor, and have been running 9.5 psi for like 2500 miles with zero problems.
Old Jan 19, 2005 | 05:41 PM
Car: 3
Engine: inboard
Won't this make my car go faster? I dunno, I'm kinda scared of speed.......can I just get one of those dogs that goes in the back window and wags it's head?
Old Jan 19, 2005 | 09:25 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
um....eric...that's the point! lol...j/k. just include the '730 doward. bump the price up a tad and go for it!
Old Jan 21, 2005 | 01:28 PM
ScrapMaker's Avatar
CRAP I thought the turbo would make my car slower!!! I guess i'd better not get it... thanks for clearing that up... whew I almost wasted all my money on speed... geez
Old Jan 21, 2005 | 04:27 PM
Car: 3
Engine: inboard
Speed kills! I'm swapping an iron duke in mine to slow 'er down....
I won't be ready for any kind of forced induction until I have at least looked at the bottom end bearings and looked at cylinder bore wear.
My plan is to get a 3.4, toss it on the stand, rebearing and re ring if needed, rework my spare set of heads with some port work etc, then put the hairdryer to it.
At the rate I get stuff done this will happen in five years.....
Old Jan 22, 2005 | 10:43 PM
devianb's Avatar
Even though I have maf, I prefer the speed density setup, I would love to ditch my maf.
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
