Car wont start, need help
Old Jan 3, 2005 | 09:02 PM
Yossarian14's Avatar
Car: 1986 z28 and 1997 Disco
Engine: Lg4 305
My friend has a 3.1 liter m in his 92 rs that wont start. He says he was starting to replace his window motor and his motor which happened to be running stopped working while he was doing this.
He took it to a mechanic where he told him that 3 cylinders arent firing but got it to work by retiming it and basically messing with the distributer yet its only firing 3/6 cylinders. So the cars running for like 2 weeks, he starts it, begins to pull out of it driveay when it stalls again and wont start.
I told him you guys could help him and hes not not a member of this site so can any of you guys help him out?
Old Jan 4, 2005 | 12:34 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
So he had the motor running while he was changing out the window motor? How long was the engine running for? A half hour? 5 hours?
And was he driving it for 2 weeks on only 3 cylinders, or, was it fine for two weeks, and now it's acting up again?
Old Jan 4, 2005 | 01:22 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Check for spark, check for fuel at the fuel rail test port, then get back to us.
Old Jan 4, 2005 | 02:30 PM
Engine: Lg4 305
Well I beleive the motor had been running for like 20 minutes while he was working on something when it died. I believe the mechanic recognized the problem when he disconnected three of the spark plugs and it made no difference, so they had like a lack of compression or lack of spark. He doesnt know much about engines and I dont know anything about his car. Specifically what could he do to check?
Old Jan 4, 2005 | 02:44 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
I believe you need to tell your friend to join up and explain the problem himself, because I believe the middle-man thing has been proven to not work efficiently.
You could start by checking for spark to all 6 plugs. You could also run a compression test on all 6 cylinders....
Old Jan 4, 2005 | 04:09 PM
Engine: Lg4 305
I understand exactly and I told him to but I'll try again, this def isnt workig because I have no clue what the problems where.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
