ok so i got my intake
Old Jan 5, 2005 | 05:25 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
3.1 v6 auto 99k
replaced the stock with a iroc dual snorkle
feels like it has a bit more power as i hoped
and sounds alot better
new
old
anyone know how much hp it added if any
going by how firebirds used the old intake
and irocs used this one
it should be @ 150hp 195lbs torque
it also has the 305 gm catback
not sure if that helps but it sure sounds nice
so many people think its a v8
short of swaping engines or turbos
anything else i can do to get a bit more power out of it?
also its leaking coolent from the back of the engine
i cant find where the leak is
anyone got some pointers?
it drips on to the bell houseing of the tranny
it uses a gallon of coolent every 2-3 weeks depending on how much i drive
Old Jan 5, 2005 | 09:48 AM
tekk's Avatar
Car: 92 ' Camaro RS
Engine: 3.1 V6
Transmission: 5 spd
Looks good man. But I dont think it added that much hp.
Old Jan 5, 2005 | 11:51 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
coolent leak from up top? Could be a intake gasket leak.
What else have you done performance wise? Click the www button below my name, I have almost every bolt on engine goodie.
Old Jan 6, 2005 | 10:10 PM
Car: 1991 camaro RS
it seems to be leaking from the back of the engine i cant see the leak from under the hood
but its leaking on to the tranny
why i said seems like the rear top of the engine
but its not comeing from the heads or where else
but you cant see a leak from peering behind the engine
its weird
someone told me it mite be a freeze plug leaking
do these engines have them?
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
