ATTN Doward
Old Jan 7, 2005 | 07:39 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
ATTN Doward
Any progress on the prototype intake manifold? I'm extremely interested in this subject, I plan on it being my next bolt on, assuming it's what I want. I'm pulling a lot of vaccum at WOT, and I imagine it's that soda straw manifold sitting atop my 3.4 causing it
Old Jan 7, 2005 | 08:08 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Some, yes.. I've got to get to the metal yard, and get the actual metal to start - but I do have the layout/design complete.
Old Jan 7, 2005 | 08:15 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
This thread is useless with out pictures
Old Jan 7, 2005 | 08:28 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: ATTN Doward
did you put a vacuum guage on it so that you can watch it while you're driving yet? i'm nearing completion of my new intake manifold. big it shouldn't be too long...
Old Jan 7, 2005 | 09:08 PM
FbodTrek's Avatar
Re: Re: ATTN Doward
yes. And I wasn't surprised.
Old Jan 7, 2005 | 09:30 PM
Car: 91 Camaro
i'm not doubting you but i don't understand how your motor will pull vacuum at WOT when i'm runnig more cam and not pulling vacuum at WOT. not pulling any real significant vacuum anyways.
Old Jan 7, 2005 | 09:42 PM
Doward's Avatar
I took a run without the turbo shortly after teh boost/vacuum gauge was hooked up, and at 5600 rpm, I was pulling about 1.5" of vacuum - it got worse as I went higher!
The volumetric efficiency of our engines SUCK at higher rpms - thanks to our free flowing intakes and exhaust manifolds
Old Jan 7, 2005 | 09:48 PM
Car: 91 Camaro
maybe my vacuum guage isn't that good...
Old Jan 7, 2005 | 09:56 PM
Doward's Avatar
What vacuum gauge are you running? What type of tubing? i'm using hard plastic line here..
Old Jan 7, 2005 | 10:22 PM
FbodTrek's Avatar
I've got a bit more displacement as for the cam, vac will be lower I thought? Maybe I'm thinking at idle...
Old Jan 7, 2005 | 11:07 PM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
Vacuum drops during WOT. With my cam, vacuum dropped to nothing. That's why I had to get that vacuum reservoir. It's good to have power brakes when you are going fast!
Old Jan 7, 2005 | 11:56 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Jerriko, that begs the question, why don't you take your foot off the gas before applying your brakes? I have.. well.. negative vacuum at WOT.. no braking problems here
Old Jan 8, 2005 | 12:21 AM
Engine: 3.4L 207 V6
I was just referring to if someone pulls out in front of me while I am at WOT. Or a light changes, etc. I just like WORKING power assisted brakes.
Old Jan 8, 2005 | 07:44 AM
Car: 91 Camaro
i don't remember what brand my guage is, i'll look at it later. i'm using some plastic tubing that cam with the guage. i have a "T" inline right after the hose exits the manifold.
as far as vacuum with a bigger cam. yea, at idle it should be lower with a bigger cam. but, if someone (you) has vacuum at WOT, I should have more vacuum since we're running the same intake and all (for now). because, my cam, being bigger, pulls more air. so, if you're pulling vacuum at WOT, i should be pulling more, other than the fact that you have a few more c.i. than me.
Old Jan 8, 2005 | 08:14 AM
Doward's Avatar
Unless that tach is inaccurate, and you're not spinning the rpms you think!
Old Jan 8, 2005 | 09:00 AM
Car: 91 Camaro
well, i've had the tach showing over 7k many times before so i would guess that the engine is atleast turning over 6k...
Old Jan 8, 2005 | 09:04 AM
Doward's Avatar
Methinks you need a new tach
Old Jan 8, 2005 | 10:48 AM
Engine: 3.4L 207 V6
I am still confused by your statement. No engine proceeds vacuum at WOT. What line did you splice the vacuum gauge into? Vacuum is created at idle, not WOT.
Old Jan 8, 2005 | 11:12 AM
Doward's Avatar
If you've got a big enough restriction (the TB or the intake) you will read slight vacuum at WOT, as well, as the airflow the engine wants increases past what the TB/Plenum can provide.
Old Jan 8, 2005 | 11:26 AM
FbodTrek's Avatar
Can happen. I spliced into the T on the back of the plenum (removed VAC control line, my heater doesn't work anyhow).
Old Jan 8, 2005 | 12:11 PM
Engine: 3.4L 207 V6
How much vacuum are we talking about here?
Old Jan 12, 2005 | 12:17 AM
FbodTrek's Avatar
About 3"....fluctuating. You can feel it being choked, you never had this problem with your motor Jerriko? Oh yeah, and:
Any news yet Doward? DId ya get your metal yet?
Old Jan 12, 2005 | 08:10 AM
Engine: 3.4L 207 V6
No, I don't have any vacuum with my motor at WOT. That would tell me that something is not right.
Old Jan 12, 2005 | 01:32 PM
TechSmurf's Avatar
Engine: LS1, Scrap
All it means is that between the back of the plenum and the air cleaner/filters, *something* is causing a restriction. 3"?! jeez. Dirty paper filters maybe? One can hope....
Old Jan 12, 2005 | 04:23 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
you can still have vacuum at wot if your intake manifold is bad enough I'm sure
Old Jan 12, 2005 | 04:56 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Or anything else, for that matter... air cleaner, filters, ductwork, MAF, throttle body...
Old Jan 13, 2005 | 07:13 AM
Doward's Avatar
Hoping to get out and get the metal this week.... I finally got enough $ to get the ZT-2 wideband O2 sensor, so the T61 is my first priority.
R3500
Aug 24, 2015 09:05 AM
zippinz
Jul 10, 2007 11:14 PM
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
duranged
Mar 28, 2005 09:25 AM
kevo2k6
Nov 23, 2004 01:27 PM
