2.8L Intake Manifold to 3.1L Intake Manifold...
Old Jan 17, 2005 | 02:26 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Ok so I did a search first and came up with nothing. Now my question is if there is a difference between the intake manifolds for 2.8s and 3.1s. I want to port my intkae manifold but I don't want to lose my daily driver while I work at it. So are they the same?
Old Jan 17, 2005 | 03:31 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
3.1 Has a vac port for the MAP sensor.
I belive the mounting where the TB goes is different.
Old Jan 17, 2005 | 04:40 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
the mounting looks a little different but they are interchangable.
Old Jan 17, 2005 | 05:21 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
where is the vacuum port on the 3.1 that the 2.8 intake doesn't have?
Old Jan 17, 2005 | 09:07 PM
Car: 91 Camaro
the 3.1s have two fittings in the back. the "T" and a single port. the single goes to the MAP sensor.
Old Jan 17, 2005 | 09:52 PM
KED85's Avatar
IF ya need to seek out a MPFI unit, also try a FWD of same early years. I believe up to 1987 is the cutoff for same stuff under those hoods.
It may be a direct replacement for a 2.8 unit.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
64goatman
Sep 9, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
