At my witts end
Old Jan 23, 2005 | 07:10 PM
Karr1986's Avatar
Car: 1986 Pontiac Firebird
Engine: 173, 2.8litre MPFI V6
At my witts end
I'm at my witts end. I know my idle speed is low, but I have re set my timing. It is set at about 11. It revs fine and sounds great in the garage. But as soon as I go to drive it, It lacks power and backfires, and backfires more the harder I push on the gas pedal. Anyone have any ideas.
Please help me
Old Jan 23, 2005 | 07:15 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Backfire:
1. Bad fuel or emissions systems
2. Timing (11 is fine if you did with the ECT dx'd)
3. Ignition problems, cap/rotor, wres, plugs, etc
5. Vac Leak
6. Valves hanging open
(not listed in my book, but I belive if the cat is plugged, it will backfire also?)
Engine Lacks Power:
could be anything not set, adjusted right, or worn. Could be more then 100 things.
Old Jan 23, 2005 | 11:07 PM
Karr1986's Avatar
Timing maybe redoing it tomorrow. Cap, rotor, wires, and plugs replaced, no vacume leaks i can tell. Fuel good refilled tank with premium. redid rockers and all new tappets( those sound better than a new cars). Any other ideas
J-money
Jan 4, 2019 09:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Sep 7, 2015 09:41 AM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
