ah crap shaking backfiring :(
Old Feb 9, 2005 | 06:55 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
well wouldnt you know it.
i took my car for an unnessesary drive tonight and noticed that just cruising at a steady highway speed the car felt like it was misfiring.
so after about an hour of driving i take the off ramp and come to a light. light turns green and i press the gas. car sort of moves, it more like shaked and backfired until i gave it full throttle. i stopped tried again. same thing. then i tried it while holding the brake. car just shook. tire didnt begin to burnout until i ave it full throttle. didnt really make much of a noise like a gear grinding noise. and its bugging me because it didnt throw a code. usually before it gets that bad it throws a code - i mean if it was tps or maf.
Old Feb 9, 2005 | 08:46 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Check your timing, and your fuel pressure.
Old Feb 9, 2005 | 09:03 AM
KED85's Avatar
Two words
Fuel Pump.
My guess.
Especially after what you described.
Fuel pressure test is the ONLY way to solve this question.
Old Feb 9, 2005 | 09:14 AM
Car: IROC Z
Engine: 5.7
i hope its not my fuel pump, i had that replaced a year ago
Old Feb 9, 2005 | 09:38 AM
KED85's Avatar
Take it back to them for a pressure test (IF it can make it).
Or borrow their guage to do teh reading yourself.
IF all parts were not replaced, yes you can have a relapse. And even if all parts were replaced, yes you can have a relaspe. Stinks.
Old Feb 9, 2005 | 10:30 AM
Car: IROC Z
Engine: 5.7
well i finnaly have use of the garage in the house im renting, so i decided to change the oil. i was gonna do that anyway.
so i had the sucker in the air and with the engine running i started unplugging things to see if it would make a diff. first thing was maf. it changed the idle. reved it up still crappy. then i touched the tps. the engine went crazy. seems the wires are frayed at the coupler. i hope this is the problem. my mechanic menioned it, bu said it was ok for now. i grabbed a spare coupler anyway from a firebird. will cut solder and heat shrink to see if its fixed. for free too.
will be back after i eat and tinker.
Old Feb 9, 2005 | 11:10 AM
Car: IROC Z
Engine: 5.7
its bloody cold in there, im gonna have a steak and beer first.
Old Feb 9, 2005 | 12:06 PM
Car: IROC Z
Engine: 5.7
jiggled the tps wires and runs like a charm
Old Feb 10, 2005 | 08:04 AM
Car: IROC Z
Engine: 5.7
nice
just shoveled the driveway and it turns over but wont start this morning.
after wiggling the wire just for kicks i checked spark. got it. plug was gas soaked too.
guess its time to change that tps coupler.
Old Feb 11, 2005 | 09:32 PM
berlinetta86's Avatar
Car: 86 berlinetta
Engine: 2.8l
Hey im having the same problem with my 86 berlinetta were is the tps couple?
Old Feb 12, 2005 | 04:09 AM
Car: IROC Z
Engine: 5.7
o mine the wires had frayed you can check this buy wiggling the wires when the car is running and revving it up. its plugged into the throttle position sensor.
my coil was also bad
Old Feb 12, 2005 | 03:21 PM
Car: 86 berlinetta
Engine: 2.8l
thanks
92-Formula
Dec 12, 2015 10:34 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Racerx974
Sep 19, 2015 10:16 AM
