Fuel systems
Old Feb 15, 2005 | 05:59 PM
Karr1986's Avatar
Car: 1986 Pontiac Firebird
Engine: 173, 2.8litre MPFI V6
Fuel systems
Ok guys here is whats up. I have 3 things
1. I have heard our cars have a secondary fuel pump mounted inside the engine compartment. What is this part called? and do they burn out?
2. What is the proper procedure for testing fuel system pressure? How much do test kits run?
3. What should proper pressure be at?
Old Feb 15, 2005 | 10:28 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
No secondary pump on MPFI motors.
The kit to test the pressure on our cars cost me $20 at Autozone and it has the little connector to screw onto the schrader valve by the back of the intake plenum.
Proper pressure should be 35-40 psi if i remember right
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
