disc vs. pintle injectors
Old Feb 14, 2005 | 04:16 AM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
hi,
whats the difference?? are pintle really better for performance?
what comes on a stock 3.4 (and how do you identify them)?
sorry for multi-question post...
thanks!
Old Feb 14, 2005 | 04:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I believe the 3.4's came with the Multec "shower-head" style injectors. Pintle injectors are supposed to last longer; I doubt it really makes much of a difference. I ran pintles for a long time, now I'm running 3.1 multecs (from a junkyard Gen II FWD motor) and they're still working great.
Multec's have a wide silver hole at the end. Pintle injectors have a plastic cap over the end with a tiny hole. Both use the same o-rings, a kit with 16 o-rings is made by Standard, part # SK-9. Always replace the o-rings if you ever have to take your injectors out, otherwise you'll get vacuum leaks!!
Old Feb 15, 2005 | 06:19 AM
oil pan 4's Avatar
Car: 89 Firebird
I have pintle injectors form a 3.8 for my 3.4L
The shower head type should mix the fuel better.
Old Feb 15, 2005 | 01:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Ya know, I never thought about that but I bet you're right; it would be a wider spray!
Old Feb 15, 2005 | 10:57 PM
Car: 91 RS,
Engine: 406ci
thanks guys!
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Keiffer76
Sep 9, 2015 08:52 PM
