Smog pump failing--should I just lose it?
Old Mar 7, 2005 | 10:10 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
My smog pump has been making noise for a few years now, and I can feel the pulley is loose, it wobbles... it still works, but I don't know how well..
I was at the junk yard the other day pulling a tensioner bracket for my car, when I noticed the car I was pulling it from (89 2.8 bird) had no smog pump... it just had a metal rod that bolted to the side of the engine somewhere, and a pulley was mounted on the end of it, a few supports kept it in place... would this be my best option, or would my car run like crap if I removed it?
I guess if I removed it I'd have to plug up all the hoses that the pump used to affect, but what else would I be looking at? What consequences would I face, other than maybe emissions? -- I'm not too concerned really, as I may even hollow out my cat.
Old Mar 7, 2005 | 10:18 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
None, ditch it!
Old Mar 7, 2005 | 10:38 AM
ScrapMaker's Avatar
should I just go back to the junk yard and snag that pulley setup, then plug the hoses, or is there more to it than that? I assume no electrical or sensors, right?
Old Mar 7, 2005 | 01:11 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Does a Smog Pump really eat up alot of power?
Old Mar 7, 2005 | 06:37 PM
ScrapMaker's Avatar
I have no idea, its just that the pulley is dying on it.. or it may be the bearings or whatnot..
just figure instead of PAYING to have a new one installed, I may as well just get rid of that POS
Old Mar 7, 2005 | 07:18 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I figure it was put there for a reason i would just leave it but thats my .02
Old Mar 7, 2005 | 11:49 PM
ScrapMaker's Avatar
I'd just leave it, but it's getting REALLY noisy... I have a feeling it will seize up sometime in the near future... taking my belt with it. I'm basically wondering if I should replace the pump, or get the smog deletion setup from a junkyard...
Old Mar 8, 2005 | 11:04 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yes when they are old and worn.
Brand new they are probably pretty easy on using up power.
smog pump is like a roots blower. cammed round wheel in a round aluminum housing. With 3-4 fins that drag and scrap on the walls to push air around. I had one apart once and it basically looked like that. Steel fin dragged across aluminum and no wonder it seized up like a rock. Had to beat it apart, there was no way or chance of making it work again. It seized.
But brand new I bet the tips and surfaces are coated with something. Probably like a roots blower. Teflon tips on the screws.
Ya only "need" one of your in a smog check zone.
I had one but took it off. My 86 has the easier Vbelts and the 86 auto trans cars had no smog pump, so a shorter belt was simple to find and install.
Old Mar 8, 2005 | 02:39 PM
ScrapMaker's Avatar
any advice on what I should do with all the vacuum hoses that attach to the smog pump? simply plug them with golf tees or what?
Old Mar 8, 2005 | 02:58 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
When mine seemed to have fallen off the car I had to make a new alt bracket to keep the next size belt tight. I also had to route it slightly different.
The vac hose I plugged with a screw.
The hole in the manifold I found some brass fitting, but it kept backing out on me. I ended up using some type of muffler repair putty, and jamming all that shiznit in, and heating it with a propane bottle to make it stick.
Wires I just tye wrapped up to something.
Mine is still laying around somewhere, at some point I would like to take it appart and see what it is/looks like. More projects then time, and its last on my list.
Old Mar 8, 2005 | 03:26 PM
ScrapMaker's Avatar
Wish I could make an S/C out of it!
what's wrong with keeping the belt I have, and using this setup I saw?
Old Mar 8, 2005 | 05:34 PM
Dale's Avatar
Engine: 350 S-TPI
I've never seen such a setup.
Old Mar 8, 2005 | 05:35 PM
FAST RS's Avatar
I saw one on an 89 RS not sure of the year i was looking at his enigne and it took me a while to figure out what was missing in that spot.
Old Mar 8, 2005 | 05:40 PM
Dale's Avatar
Engine: 350 S-TPI
Attached Thumbnails Smog pump failing--should I just lose it?-c-jay-camera-img_1215
FAST RS's Avatar
How exactly does a smog pump work to lower emissions?
Dale's Avatar
Engine: 350 S-TPI
well if anyone comes across one of them gizmos, ****** it and let me know
Old Mar 9, 2005 | 10:40 AM
ScrapMaker's Avatar
I may have to go snag that off that car... I may have to replace the pulley though, as its been in the rain so long.
mustangman65_79
Apr 14, 2017 05:37 PM
italiano67
Dec 11, 2016 09:21 AM
formula_novice
Sep 5, 2015 03:58 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
