Intermittant Code 45
Old Mar 30, 2005 | 10:21 AM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Code 45 is "Oxygen Sensor Rich"
The thing is, it only happens intermittantly. On my way to Michigan, it went on and off a couple times within about a 20 minute period and there was no performance problems associated with it. On the way back there were no codes thrown. Then this morning, it did it again, it was about an hour ride and it threw this code on and off for about 5 or 10 minutes.
So, any suggestions? My car does generally run rich (according to the smog station) but has never thrown a code about it before now. Also like I said I can feel no performance problems when the code is "on". So engine trouble or O2 sensor crapping out? (the sensor is only about 2 years old)
Old Mar 30, 2005 | 02:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Check the oxygen sensor's wire; make sure that it hasn't melted against the y-pipe. That'll cause it to ground out and throw the rich code. Also check the connector to the oxy sensor pigtail; mine melted and cooked on the y-pipe which threw a 45.
Old Mar 31, 2005 | 02:52 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
It shouldn't throw a rich code when you melt the wire to the exhaust.
You'll get a lean code because it's grounded and nothing is getting back to the ECM. When the voltage is near 0, it'll try and force it richer until it reaches it's maximum adjustment, then it should throw a lean code.
Old Apr 6, 2005 | 04:55 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Im getting a code 45 as well. My friend told me dat my car is giving some sort of low voltage. Maybe my oxygen sensor got disconnected because if u buy it from autozone or kragen, its hard to mount the harness. I should recheck my O2 as well.
Old Apr 13, 2005 | 11:53 AM
l98+t5's Avatar
Car: 1988 camaro iroc-z z-28
Engine: L98 5.7 liter 350
Transmission: T-5 manual 5-speed
same situation here. just happened about 20 min ago. also it doesnt ever idle the same way its usaully all over the place anywhere from 450 to 1,500 tps and iac are new and properly adjusted. no idea whould this be caused by a gutted maf?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Reid Fleming
Oct 10, 2015 09:56 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
