fun at a dealership
Old Apr 12, 2005 | 12:50 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
fun at a dealership
so check this out right
my girl takes my car upto the local ford dealer for some diag stuff on it (seem to have good luck with this dealership and service so i don't mind) they turn around and tell her that my car is only going to run for about 2 weeks or so, kinda odd though when i asked to see a paper on it they told me it didn't exist, however my car was throwing a whole bunch of codes out (i hooked up a jumper wire to have it link at me) and the only one i got was a 22 which is the TPS, also the team leader when he brought my car around said that he hasn't seen my car until he got it himself and the other mechanic had gone home already and didn't report anything to him about it but from what he could tell in the 5 seconds of drive it was that i had an exaust leak(which i'll admit to), i was burning oil (which i highly doubt), and that it was going to die real soon,
Old Apr 12, 2005 | 03:12 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
but for just 4,000 down we can get you in a brand new GTO! it has everything...powerdoorlockspowermirrorspowersunroofpowerwindowstiltsteeringlumbarsupportelectricseatblablablablablabla.......
and you had suck good luck with them in the past. commision is a terible thing....
Old Apr 12, 2005 | 03:53 PM
electragup's Avatar
Car: 89 tta trans am
Engine: 3.8 L turbo
beautiful A good mechanic is impossible to find. out hear in IL they want $200.00 just to hook it iup to diognostis. $90 for the hookup and $110.00 for one hour shop rate. These dealerships are getting as bad as lawyers
Old Apr 12, 2005 | 05:30 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
damn, it cost me $65 to have my blazer hooked up, and they dducted that from the final price (fp replacement w/full tank of gas = dealership problem )
Old Apr 12, 2005 | 11:58 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
never take a car that old to a stealership.
i had them try to break my car so id buy a new one.
fine a good reputable mechanic that works on older cars, and he can probably fix yours in less time for alot less $$$
or learn to do it yourself.
Old Apr 13, 2005 | 03:29 AM
Xophertony's Avatar
Axle/Gears: n/a
amen. i have only had a few things done at a shop.
1) frame shop fixed my frame
2) had napa press in ball joints and LCA bushings a few times.
3) exhaust wealding (i no have wealder or could have done myself)
Old Apr 13, 2005 | 07:21 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
if you have autozone's in your area they'll do a code scan at least for free and tell you what it is and all that. As far as diag just click the lil ole search button on here and find out what you broke for free.
Old Apr 13, 2005 | 01:57 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
well i just wanted to express my results with you guys and also one question
when i hook the jumper wire up to the aldl will i get the same codes as with a scanner?
Old Apr 17, 2005 | 03:33 AM
Xophertony's Avatar
Axle/Gears: n/a
i don't see why not, the only thing of it is you must read the code from the blinking SES light instead of however the scanner puts it out. the light will blink once and have a brief blank and then blink twice quickly for code 12. it will do this 3 times. if you do not recive a code 12 your ECU is bad, or your bad at reading codes. then after the 3 code 12s the real codes will start going. ex. blink....blink....blink....blink.blink.blink.blink. blink....blink....blink....blink.blink.blink.blink. code 34.
there is also a tech article on how do do this somwhere.
Old Apr 19, 2005 | 07:01 PM
Th33nforcer's Avatar
Car: '88 Camaro
Engine: 2.8L - V6
So how does a Ford dealership sell GTOs (Pontiac)? That would really be interesting...
blackz281le
Jan 11, 2016 07:51 AM
92camaro350cci
Oct 14, 2015 09:29 AM
92projectcamaro
Sep 29, 2015 07:07 PM
F-body-fan
Sep 17, 2015 12:16 PM
