Another intake question.....
Old May 17, 2005 | 03:18 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Well, I looked at some intakes and I am very impressed and it just makes me want to do it even more! lol
However, being the cheapskate that I am I am currently going to leave the air intake box up to the MAF sensor and build it from there to the throttle body because I recently just spent some good $$$ on a replacement stock K&N air filter and i'll change it all at a later time I suppose when I get some $$$.
So my question involves the metal pipe that comes out of the valve cover on the passenger side and then goes into the air intake snorkel. What did you folks do with it? How did you hook it up....assuming you made an intake which changed the snorkel on the throttle body of course Thanks!
Old May 17, 2005 | 03:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could always fab up a new box for your K&N; turn it into a conical filter.
If you got some flat steel plate from Home Depot ($6/sheet), you could cut two circles; one for the top and one for the bottom. Tie them together with some long threaded rod and some nuts; that would seal both ends off.
Of course that's not good for airflow (ha, ha) so you'd have to open up one end, I'm sure you could bend some kind of adapter to take a hose. Such as, taking a coffee can, cutting "halfway" up it 6 ways, and bending each of the 6 pieces out- sort of like a flower- and attaching it between the air filter and one of the plates. Add some black RTV... or better yet, a flat piece of rubber (no idea where you'd find that) as a seal, and you've got a conical on the cheap. Such as this picture...
Attached Thumbnails Another intake question.....-make-kn-conical-adapter.jpg
Old May 17, 2005 | 06:15 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
Re: Another intake question.....
i have no idea what you are talking about. the only thing that even sounds remotly like it is the preheater, and not much you can do about that. it's neccisary from what i understand.
Old May 17, 2005 | 07:14 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: Re: Another intake question.....
Truth be told, I have no idea what it is called either! On the driver side is the PCV valve, but on the passenger side, there is basically just a pipe that goes from the valve cover to the air intake snorkel. There is no valve or anything...it's just a rubber gromet that feeds into the metal pipe. Anyone know what this is?
Old May 17, 2005 | 08:13 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
it's a function of the pcv circuit. it suks the fumes out of the internal engine & lets them get mixed w/teh incoming air. Think of a really vacuum pump, w/the intake taking in the air from teh engine
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
