Need a little help
Old Jun 1, 2005 | 09:54 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Need a little help
Maybe you guys can help me fix the only two things wronge with my car besides the clutch lol
Heres the first:
I cracked the T connection there in that main vacume line. How can i fix this? Do I have to pull the top off the plemun?
Heres the second:
I have exhuast leaks around where the base of the tubes go into the manifold. Is there a way to fix this without buying a new manifold? And where can I get some of the heat shields around the spark plugs. Good idea. Thanks again
Old Jun 1, 2005 | 10:03 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
any parts store will have a vacuum kit that will have the "T" connector.
if you dont have emissions testing, take them out and the AIR pump off and plug the holes up. if you do, you may have to find find a sealer of some sort. i wouldnt think youd need a new manifold or anything, unless the threads are destroyed.
Old Jun 2, 2005 | 12:26 AM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
JBWeld em? I duno
Old Jun 2, 2005 | 01:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
For What Its Worth, I pulled those spark plug boot shields off when I got the car in 1994 and never put 'em back on. Didn't see a reason for 'em, and never had any problems with them missing.
Just make sure you put dielectric grease in the spark plug boots before connecting the plug wires- but you should be doing that anyway, with any car.
Old Jun 2, 2005 | 10:47 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Thanks guys. So any other advice on those stupid egr lines? I can here it and it bugs the crap out of me
I tried get that vac line off today. It seems like its all one peice? Don't want to break it more. It just sits on there for now. Could it be glued maybe? Thans again
