cat back question
Old Jun 9, 2005 | 03:13 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
cat back question
I bought a camaro at the begining of winter last year, so im kinda new to the engine concepts. At summit they have a catback that i like(WLK-17495). Would this fit on my 1991 camaro RS V6? The pipes are the same size as what i have, but they say its for the V8. Will it fit or should i go a different route?
Old Jun 9, 2005 | 03:23 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
I don't believe it will fit, right now your stock set up has a Y-Pipe configuration. So, you only have one pipe to the rear of the car until it splits in the muffler. I think the v8's have an X-pipe, meaning two pipes run to the back. I might be wrong about the X-Pipe configuration, but normally V8 and V6 parts do not swap out.
Old Jun 9, 2005 | 03:42 PM
grimmcs's Avatar
Car: 91 Camaro
ok thanks. i thought they would meet in the same place. oh well. back to the drawing board.
Old Jun 9, 2005 | 05:03 PM
camaro1fan's Avatar
Car: 1990 RS
but you can get WLK-17493 for your car.
Old Jun 9, 2005 | 06:48 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
I picked up a dyno max cat back system for my 3.1(soon to be 3.4 thanks to KED's advice) and it sounds phenominal. really deep tone, and it sounds great throught the RPM range. word of caution however, when trying to seperat current exhaust from catalytic converter, the bolts are probably rusted in place. I had to torch mine off, so if you encounter that problem be ready to either cut or use a lot of PB blaster on it.
Old Jun 9, 2005 | 07:20 PM
grimmcs's Avatar
Car: 91 Camaro
On my car i just changed the y-pipe and cat and the intermediate pipe was changed not to long ago so it is still good. All i need is the muffler and tips. I like the tips that come with the 17495. Does anyone know where i could buy tips like that? I want them to stick straight out the back about an inch or two.
Old Jun 9, 2005 | 08:09 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
pep boys has a very nice set of tips, little expensive but give em a try.
Old Jun 10, 2005 | 05:20 AM
86BLUEBIRD's Avatar
Car: 86 Firebird 2.8
Engine: 2.8l v-6
Transmission: auto
just buy the super turbo muffler and tips and have an exhaust shop make up some tail pipes to fit it.
Old Jun 10, 2005 | 07:19 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
most people have gone with the dynomax catback exhaust. its got good sound and a lil performance to it. if you just want sound, you can get a muffler, but if youre looking for any kind of gains, youre going to want to get rid of that I-pipe, unless you already have a mandrel bent one. most catbacks have a bigger I-pipe and theyre mandrel bent. that was one of the best bang for the buck mods i did, aside from headers.
Old Jun 10, 2005 | 10:43 AM
grimmcs's Avatar
Car: 91 Camaro
I do have an aftermarket i-pipe. I was looking at mufflers from dynomax. Would an Ultra Flow SS be better that the Super Turbo, or is it the other way around?
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
