Could this idea be useful?
Old Jun 16, 2005 | 04:03 AM
mieta's Avatar
Car: Camaro 1990
Engine: 3.1 v6
Just an idea. Could one make a spacer between upper an lower intake manifold to get rid of that sharp bend between them. Would it make the intake good enought for our engines?
Old Jun 16, 2005 | 04:28 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
well the problem would be that you would have to have a cowl hood to fit it and im not sure how much better it would flow being that passageways are quite small to begin with
Old Jun 16, 2005 | 06:32 AM
87blueracr's Avatar
Car: 1987 camaro & 70 mustang
Engine: 2.8l & built 351C
Transmission: borg warner T-5
on a stock hood, you have 2 inches above the top of the intake. if you think that you can do it, but you really aren't gonna gain anything cause the thing has passages that are too small. if you are thinking about porting the intake, good luck
Old Jun 16, 2005 | 07:50 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i did that, too. i ran 1/4" spacers for a while. had them laser cut to match the gaskets. didn't notice any gains. i pulled them out while i was at the track and the car ran the same. i was a bit surprised that they seemed to make no difference.
Old Jun 16, 2005 | 08:29 AM
87blueracr's Avatar
i mean you could try 1 1/2 spacers and see if it does anything, but i really don't think it will work like am91 said from experience!
Old Jun 16, 2005 | 10:35 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
That won't change the rate of flow of the plenum. All you'd be doing is increaseing the volume of it. We need bigger passage ways, and there isn't enough material in a stock plenum to open up the holes/passages enough to make a noticible difference.
Old Jun 16, 2005 | 02:19 PM
mieta's Avatar
Car: Camaro 1990
Engine: 3.1 v6
Ok, so the problem is the passageways not the volume of the manifold.
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
