Jacking point
Old Jul 27, 2005 | 11:34 AM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
Jacking point
Can i jack my car up from the center of the rear end?? I think it would be fine but I just want to make sure
Old Jul 27, 2005 | 11:41 AM
Tha_Villain's Avatar
Car: Camaro RS
Engine: 2.8 L
put it under the diff cap
Old Jul 27, 2005 | 07:33 PM
KED85's Avatar
ONLY DOWN SIDE TO THAT IS
The axle rises and the car will eventually lift.
IF that situation works OK have at it.
And yep MAKE SURE the axle is secured in jack "pocket".
PS Use jack stands, too.......and watch out for that balancing act that's gonna occur.
Old Jul 27, 2005 | 10:10 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
I do it to mine whenever I rotate the tires. I lift the front end, put it on jackstands, then use the jack under the difff. With 3 points on the ground, as long as everything is secure, then you won't have to worry about it comming off and falling.
Old Jul 28, 2005 | 07:47 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
that's where i always put the jack on mine, also.
Old Jul 28, 2005 | 05:12 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
millions of times problem free, however NEVER work on a car while suported by a hydrolic jack alone. i used to do it "to grab that bolt real quick" or "just need to look at somthing real fast" untill i had a jack ( a nice jack too) all of the sudden start dropping a little quick. i went in the house fore a cola, came out and the jeep i was working on was resting on the brake drums! (in this instance i was not working unter the jeep, it was a brake job, the jacks just put it at a mor convenient height.)
Old Jul 29, 2005 | 02:39 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
When it comes to jacks dont get the 30 dollar ones the one i used to have the weels would aways come off scared the hell outta me when i was under the car. Then i began to use jackstands for V-Day my G/F got me a almunium craftsmen jack very very nice jack and you dont have to pump it as much to jack up the car i think i only need to pupit 4 times and it will be as high as it will go.
gixxer92
May 18, 2017 11:20 AM
z28joe2
Sep 28, 2015 05:54 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Lmancha96
Sep 25, 2015 08:11 PM
lanceflame44
Sep 25, 2015 12:28 PM
