Edelbrock Intake Manifold for 2.8!
Old Jul 28, 2005 | 01:54 AM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Found this looking through the Summit...Part number is EDL-3785
Says Chevy , 2.8 Liter V6!
Anyone else knew this thing existed?
Old Jul 28, 2005 | 07:46 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i'm pretty sure that is the one that is the base for the carb setup.
Old Jul 28, 2005 | 08:02 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
it the one I am planning on getting it is for carbs. the intake is a 2 peice setup it hase the base the the top is changeable from 2bbl to 4bbl. works nice for the 4bbl with either a 390 or a 450 for a major moded engine
Old Jul 29, 2005 | 10:05 AM
KED85's Avatar
They are "pricey".
Looking at about $400 total intake
and
carb goes for about $300-ish new.
IF ya score them used DO SO!
IF ya want to buy the 2 barrel set up, increase the height of the factory intake slightly, for near same results.
I plan on trying that idea on my 1985 Blazer stock carb set up. My hold up on the execution is finding the longer bolts that hold carb to intake for my experimenting.
In end you are creating the longer runners that comes with Edelbrock set up.
That intake been around since atleast 1983.
IF you know welding, you can take a 4 barrel intake carb base and weld it to the factory manifold. Bill Grumpy Jenkins did that back in early 80's. Results were gains, too.
Best deal is scoring them used....these items are proven power gainers......
Old Jul 29, 2005 | 10:11 AM
Parrydise7's Avatar
That intake has been around for years.
If that's not enough for you, there is an adaptor that can take 3 two barrel Weber carbs. Don't count on passing smog.
Old Jul 29, 2005 | 10:18 AM
KED85's Avatar
I haven't heard mentioned that 6 pack intake for ages.
Last I saw it was in the old Chevy Power parts Bible of late 80's.
That's a real rare score. I recall Chevy promoted it for the V6 powered Sprint car set up (with Webers).
The Edelbrock assembly is much easier to score.
Old Jul 29, 2005 | 11:59 AM
Parrydise7's Avatar
You definitely know your 60 degree V6 intakes, don't you!
Old Jul 29, 2005 | 02:45 PM
KED85's Avatar
Stupid me been playing with stupid cars for so long stupid me learned some tricks.
But serious, I recall reading the article of Grumpy Jenkins beefing up a V6 from Blazer/F Body when they first came out back then.
And the Carb'd intake is aluminum (as is a 4 bbl Chevy 350 intake). What Grumpy created wasn't exactly pretty but it proved the idea is effective.
This "design" was prior to Edelbrock making theirs.
I got lots of old pubs & such. Good resource information.
And seriously IF ya study the Edelbrock item, it "looks" NEARLY identical to the issued GM intake. Edelbrock "says" is theirs is "slightly taller" (hood clearence issue right!?), which accounts for my idea of mearly taking your stock one & adding a spacer to make it better! A couple of carb gaskets is cheap experimenting material, right?
I figure you mearly add like up to 1" taller for carb off base & all should be "better".
This idea has been used for ages, look at many other intakes, longer runners equal more power (not MUCH.....).
Old Jul 29, 2005 | 10:37 PM
Car: 91 RS
Engine: 5.0 tbi
I need a set of carb studs to put on my new carb because my new carbs linkage is a half inch lower so it hits the valve cover.
Old Nov 10, 2006 | 07:47 PM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
Smocky Yunick took the stock chev. 2 brl. intake and made it a 4 brl. intake before my hero Bill Jenkins did.
Old Nov 10, 2006 | 09:44 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
wow! this was an old thread to revive. Pay attention to the dates on posts before you reply.
Old Nov 11, 2006 | 06:51 AM
Car: 1987 TransAm
Dood, I know exactly when this thread was started July 28, 2005. I have a degree in engineering and am a ASE certified technician. I don't miss a trick. I am doing some research, looking for a thread, I wrote the responce to over a year ago. It is about 60 degree V-6 camshafts.
Old Nov 11, 2006 | 11:41 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
