dynomax catback question
Old Aug 18, 2005 | 08:13 PM
kwyjibo's Avatar
Car: 1987 ford mustang gt
Engine: 5.0
Transmission: tremec t-5
well i need a new exhaust by the end of the month to get through instpaction and ive read the forum and yes i did search and search again, found a LOT of good information, and decided the dynomax super turbo sounds best,
however still have 1 question on the system
does the I-pipe fit on a stock cat no problem with just the clamp, or will an adapter be needed?
thanks, matt
Old Aug 18, 2005 | 08:17 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
it should bolt up fine. whats the point in making a vehicle specific exhaust system if it doesnt fit without modification?
Old Aug 18, 2005 | 10:32 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
It will bolt up perfect
Old Aug 19, 2005 | 03:46 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Direct replacement, while your at it get a high flow cat.
Old Aug 19, 2005 | 05:11 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Be prepared to have some fun removing the bolts from the current exhuast flange to the cat. I had to torch them off from being rusted for so long. Just a heads up, I hope yours goes smoother than mine did. Sounds great once some carbon builds up.
billybob6110
Sep 24, 2016 09:50 AM
transaero
Aug 31, 2015 01:14 AM
midias
Aug 22, 2015 01:42 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
