.... Oil pressure...
Old Aug 24, 2005 | 09:15 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
I did a search but i couldn't quite find what i was looking for in an answer. heres the low down...
im reading almost Nil oil pressure on my stock gauge (yea i know, it aint accurate) when im accelerating, Then when i get to cruizin speed it's in the red zone I hear a tapping sound (possably coming from the cat from bottoming out earlier this year on a speed bump)at idle and as im accelerating, only time its audiable IN the car is with the radio shut off and near a curb or a another car/truck is beside be. Could it just be the oil presser sender/sensor? or is it the Oil pump itself? anybody got anyother ideas on what it could be?
Old Aug 24, 2005 | 09:53 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
get a gauge and hook it up to see what your oil pressure really is, thats the only way to know for sure. but if youre getting a noise, it could mean something bad. start by getting a gauge from sears or autozone or somewhere, let us know, then well see where to go next.
Old Aug 24, 2005 | 10:10 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Ill go get one as soon as i can, Hopefullly its just the sender unit and not the pump.
Old Aug 24, 2005 | 10:14 PM
drdave88's Avatar
Engine: 6.0L
do you hear any noise from under the hood at idle? rev up the engine, see if you hear any noises at all, you should if theres any engine knocking. maybe youre gonna get lucky on this and itll just be the sending unit.
Old Aug 24, 2005 | 10:22 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
ill have to check that out. Hopefully i will get lucky
Old Aug 25, 2005 | 01:31 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
its the oil pump, the ticking is the top end not getting any oil ... is their any short cuts or any thing i should do to make this replacement easier any tips on how to take the oil pan out? i got the haynes manual and it looks like its gonna be an ALL day job
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
