Update to Adjusting Hydrolic Lifters
Old Aug 27, 2005 | 07:02 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Well to make a long story short the lifters were never a problem. The timing was never set right. After I asked my dad if we ever set it correctly he told me no. Keep in mind this was after I went back in and backed off them. Now my baby sounds like a sewing machine. So you all know what I have to do now. Hey its a learning experience so I am ok with it. Just believe that it will never happen again.
As to say though the cam that I put in has an awsome sound and I get good response from it. So if you want a good after market cam that works good with your stock everything else here it is with the specs:
Part Number 16-115-4
Engine 1979-1994 Chevrolet
2.8ltr-3.4ltr
173ci-207ci
60 Degree,
6cyl.
Grind Number CSV-6 240H-8
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.39 0.39
Duration At 0.006 Tappet Lift 240 248
Valve Timing At 0.006
Open Close
Intake 12 48
Exhaust 52 16
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 192 200
Lobe Lift 0.26 0.26
Lobe Separation 108
Recommended Valve Springs 980-12
Hope everyone get some good out of this post.
Also to add. We did set the timing where it was before we took everything apart. What we realized was the timing never was right from the time I brought it. So that could have been the problem all along and never need a cam, but I wanted to up grade that anyway.
Derick ( 2.8L V6 Freak)
J-money
Jan 4, 2019 09:45 AM
codeysabatini
Nov 10, 2015 04:07 PM
aharvel50
Sep 21, 2015 07:31 PM
hydrolic144
Sep 8, 2015 06:59 PM
dimented24x7
Sep 6, 2015 03:51 PM
