Wont start, replaced cap / router
Old Aug 27, 2005 | 06:05 PM
Switch Avenger's Avatar
Engine: PoS!
I have a 1988 camaro RS, a while back ago i was having problems with it running (it turned out to be a spark cable that was frayed and started flashing) and i replaced the cables and plugs and then it wouldn't start (was about 5 months ago). I've finally found the time to try to **** with it again. So i get it try to crank the engine over and it just cranks, so i pull out a plug and see if it sparks (5 months ago when i gave up on it because of work / college issues i used to spark just fine). now it doesn't do anything, i replaced the coil and center piece, it was all nasty inside. and still no spark, i was thinking that it could be the ignition coil, but i'm not sure. It seemed that it wouldn't start up 5 months ago because there wasn't enough fuel to the engine, but i'm not starting to think thats not the case. when i pulled out the plug there was a nice smell of gas and there was some fluid on the plug. Any ideas on what it is? thanks!
Old Aug 27, 2005 | 06:13 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
fouled/corroded plug not firing due to lack of/no spark. Is it the same gas that was in it 5 mos ago?
Old Aug 27, 2005 | 06:15 PM
Engine: PoS!
yeah same gas, new plugs and wires, the plugs are still kind of fresh, no carbon build up
Old Aug 27, 2005 | 08:17 PM
Engine: 5.7 / 7.4
YOU NEED TO EITHER REPLACE THAT GAS, OR (stupid cap locks) or put in some additive to help burn that crap. trash gas doesn't help all that well w/carbs, and probably isn't all that good for fuilies either.
Also verify fp while you're troubelshooting. helps eliminate things as you go.
Old Aug 27, 2005 | 08:37 PM
Engine: PoS!
well... gas isn't really what i'm trying to fix, it's the fact that i don't have any spark to get anything to ignited. replaced the distributer, center piece, was thinking it could be the ICM or something. I don't have spark on the main wire coming from the ignition coil doesn't fire (was using a plug tester). so lets start from there.
Old Aug 27, 2005 | 08:43 PM
Engine: 5.7 / 7.4
ok, unsing a dvm or line voltage checker, verify you're getting 12v+ to the distibutor (wishes his service manuals were accessable right now for wire to check )
edit: icm are easy to check, just make sure to regoop it when putting back on
Old Aug 27, 2005 | 08:47 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
checked the ignition module?
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
drathaar907
Aug 6, 2015 04:20 PM
92projectcamaro
Aug 6, 2015 01:20 PM
