La dee da....
Old Sep 4, 2005 | 04:08 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
La dee da....
7psi, running good - with one small exception.
MY PCV VALVE.
arg... I've got one from a Turbo Grand Prix in there (oddly enough, same p/n as our stock one) but I go under boost, and out she comes. I need a 3/8" one way check valve.
Any ideas?
Looked into maybe a brake booster valve, but nothing. I may end up building my own
I go do a nice WOT run, and stop - PCV valve is blown out. I'm going to do a compression test tonight, to verify I haven't killed the rings with all my tuning, LOL. I'm certain they aren't the problem - no blue smoke when not WOT
BTW - I'll be out at the track Wednesday if anyone wants to check out the turbo 3.1
Old Sep 4, 2005 | 04:45 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
What side of the turbo is the Breather Hose routed to? It needs to be on the Inlet side so you're not building boost into the crankcase. if the PCV valve is working right, when you go into boost, it should be closed because the boost is holding it shut, so nothing gets into the crankcase.
Old Sep 4, 2005 | 06:09 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
probably just easier to fab something up that work the way you need it to
Old Sep 4, 2005 | 06:55 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i'm doin the same thing without a turbo! lol...that thing won't stay in my valve cover either. i figured it was cause of my edelbrock covers though...
Old Sep 4, 2005 | 07:25 PM
Doward's Avatar
New valve + grommet, seems to have cured it. The old grommet was BAKED.
LOL
Old Sep 4, 2005 | 07:26 PM
Doward's Avatar
Also, PCV routing as follows -
Driver's side, stock
Passanger side = run to right before the turbo inlet Need to get a catch can tho, I'm pulling some oil through it (hey, who'd have thought? a 3" MAF is a fairly large restriction to a 4" turbo inlet?)
Jeremys87
Jul 14, 2022 09:08 PM
lumpie
Jun 30, 2016 11:16 AM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Nick McCardle
Sep 10, 2015 08:36 PM
