Camshaft
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Camshaft
I have heard dean talk about this cam before i was wondering if it is the best possible cam for my application. Im keeping stock compression and one day will turbo it but for a year it will be all motor. Does this cam have a nice lope at idle. How much hp and tq should i gain with this cam on a stock motor.
comp cam
comp cam
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
With stock compression. that will be a bit of a big cam... It shouldn't be too bad, but you will need some PROM burning to really take advantage of it!
As for turbocharged... I think it'll do fine
Make sure you have some headers when you turbo it, though, with a slightly larger than what-you-would-think turbine side (if you are thinking .48, go .63... if you are thinking .63, get a .70) You do not want large amounts of back pressure with that cam.
Make sure you have some headers when you turbo it, though, with a slightly larger than what-you-would-think turbine side (if you are thinking .48, go .63... if you are thinking .63, get a .70) You do not want large amounts of back pressure with that cam. Senior Member
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Go with a shift kit, then cam and then tuning. THEN turbo
Youll have yourself a trans am *** ripping 3.1!
Maybe a fuel pressure regulator after that? To add the extra fuel from the high flow intake/exhaust and cam and turbo..
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
You may want to get a high temp thermostat and hp chip with this cam. You can also order directly from comp cams
http://www.compcams.com/ or call 1-800-999-0853
You will save a few bucks and get the cam a little faster than ordering from Summit. I ordered mines straight from there and got it in a few days. Just a lil info to help you out.
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
