dumb question
Old Sep 8, 2005 | 08:18 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
dumb question
there are two sensors at the driver frt of the intake manifold, i know one is the coolant temp sensor, but what one? the one on the outside or the inside? i think the one on the inside (closer to the pass side) is the coolant temp sensor, its on an 85 camaro, not mine.
Old Sep 8, 2005 | 08:57 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
You're right.
The one on the inside is the Coolant Temp Sensor for the ECM.
The one on the outside is the Cold Start Switch.
Old Sep 8, 2005 | 09:01 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
on a "2.8" their is, on a "3.1" their is not.
Old Sep 8, 2005 | 09:42 PM
drdave88's Avatar
Engine: 6.0L
its a cold start switch? hmm, i never knew that. alrighty then
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
