2.8 carb block to FI block, questions
Old Sep 12, 2005 | 10:41 PM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
Hey guys,
I'm getting ready to drop a 1988 FI 2.8 block and heads into a 1982 Camaro, and intended on keeping the carbureted setup. I was told on this forum a while back that the blocks are compatible with the only exception being the fuel pump port being absent from the MPFI block.
However, looking between the 1982 motor and the 1988, I'm wondering: will I be able to switch the 1988 motor from a serpentine belt system to the 1982 V-belt setup? I'd leave the serpentine setup if it weren't for the different alternators between the two. But I can't quite tell just yet if the accessory mounting brackets will be interchangeable between the two motors or not. Will all of the mounting brackets transfer from block to block?
Old Sep 15, 2005 | 12:17 AM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Re: 2.8 carb block to FI block, questions
Originally posted by CamaroManBlack
Hey guys,
Yes, you can swap the belt set-up.
You need to change the timing chain cover as well, due to the reverse rotation water pump. The bolt holes in the end of the heads are the same.
You could always just swap the pulleys between the alternators, or change the one plug that needs to be changed to update the alternator.
Go.
Old Sep 15, 2005 | 04:36 PM
Car: 1984 Camaro
thanks for the affirmation, Raven
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
