engine bay cleaning clutterness
Old Sep 13, 2005 | 02:10 AM
88firebirdguy's Avatar
Car: 83 recaro, 82 grandprix, 72 skylark
i got a stock 88 firebird with a 2.8MPI under the hood, what junk can i remove under the hood without messing with the computer?
Old Sep 13, 2005 | 04:38 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
cruise control. go with custom intake (made by you out of plumbing pipe, see CAI link in my sig for an ok one) clears up a bunch of stock airbox crap. your no longer working AC . anything else (like evap can, A.I.R injection "smog" pump, or EGR) will require modifing your computer to be done right.
i am sure there ore others, but i can't think of anything.
i supose if you are real desperate to free up space you can relocate a few things, i moved my evap can down into my fender for a while, you can relocate the batery, and i just read THIS thread about switching to a 4th gen washer fluid bottle so you can relocate that as well. good luck.
Old Sep 13, 2005 | 11:59 AM
how do you modify the computer to accept removal of the smog pump and charcoal canister and stuff?
Old Sep 13, 2005 | 06:07 PM
Mr_Metal's Avatar
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
Re: engine bay cleaning clutterness
Here's an uncluttered engine bay w/ a little bit of elbow grease applied:
Old Sep 13, 2005 | 07:02 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
can remove smog pump w/o ecm modifications. Its the belt routing you have problems with.
Remove AC
relocate battery
that washer fluid thing just posted (I like that, thanks x!!)
redraif relocated her charcol canister I belive.
Thats about it. Unless is show, or drag race, its not really worth all the effort. These things are quite easy to work on as is.
Old Sep 13, 2005 | 11:17 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
here's my uncluttered engine bay
oh wait, that's what it looked like.
Old Sep 14, 2005 | 08:30 PM
Xophertony's Avatar
Axle/Gears: n/a
what what looked like? i dont get it?
also, if you remove the smog pump w/o modifing the computer you may not be able to pass DEQ/SMOG/EMISSIONS because your ECM is counting on the exhaust gasses running back through the plenum and since they wont be your car will be running rich (i think it's rich, somone will no mmore about this then me. i just know it leads to greater emmisions and is BAD)
if you are set on doing it though it won't make the car run goofy or anything, it will just affect what comes out of the tail pipe.
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
