WHOA....My car is going hey wire need help
Old Sep 20, 2005 | 11:40 AM
Drunk_monkey's Avatar
Car: 1992 Chevy Camaro RS
Engine: 3.1L 60* V6
Transmission: 4 Speed Automatic (700-R4)
O.K..I started my car the other day and it was shaking like crazy....I thought maybe a vacuum hose came loose, but no...the car is not loosing any vacuum..
I though it could be my spark plugs or spark plug wires....but I noticed when I turned on the head lights, All four went on, even though it's on low beam....also my left parking signal is really weak, when I signal the weak driver side head lights flash intermittantly....
What the hell could it be....oh and a great addition, is the windshield wipers aren't working either....as if their not getting enough current, be cause I hear the motor tick.....
any help would be greatly appreciated.
Old Sep 20, 2005 | 12:19 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
Shaking...
ok, that in itself will lend to mounts going bad. Engine, trans... if moving you can include more...
Running poorly is entirely different, so you need to get a little more detailed...
Electrical devices not working... Bueler? Bueler? try looking at the Volt guage and having the Alt and battery tested...
I am not adding or saying anything else until you get a littl emore info up here...
Old Sep 20, 2005 | 12:21 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
well please note im no expert., but maby check all your fuses., also it seems as if somthing has short fusedperhaps checks the wiring under the hood have you recently instald something electrical that may have interfeered?
Old Sep 22, 2005 | 04:06 PM
Engine: 3.1L 60* V6
thanks, for the reply guys....
I found the problem..it was one of the head light ground wires that is near the battery it was broken off.....
It fixed the lighting issue, but I discovered that ny exhaust manifold leaks at the gasket.....do you think that is causing the egine to run a little rough?
cause the car runs ok, but the engine just kinda vibrates a little too much than normal
I'm gonna change all the vacuum hoses, put a new cap and rotor, plug wires and plugs, oil filter, fuel filter and a new canister filter, and see how the car runs after that.
Old Sep 22, 2005 | 06:51 PM
V6sucker's Avatar
Engine: blown up
it would have to be bad to throw off the O2 sensor...
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
mx127
Aug 10, 2015 08:13 AM
