EGR & custom upper plenum
Old Sep 23, 2005 | 02:00 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Taking my upper plenum off and then milling down my lower plenum, porting it and making a custom upper. Do I need the EGR or can I just hack it off or route it somewhere else.. dont really want it but I heard if removed you run the risk of melting your pistons??
Old Sep 23, 2005 | 04:58 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
it helps stabilize your cylinder temps.
Also recirc's fuel rich gases.
Will it do any real damage? no.
COULD you see some drivibility issues? maybe.
That and the constant SES light... that alone would annoy the hell outta me.
Old Sep 23, 2005 | 05:31 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Hmm...what year is your car? 2.8 so you should have the vacuum controlled EGR, but I'm not sure when they changed it.
The light only comes on if you have the electronic EGR (disabled). The ones with the vacuum hose on them won't trip the SES, ecu doesn't know if it is working or not.
If you don't have to worry about emissions and having it look stock, just take it off and block off the hole on the exhaust manifold, and cap the vacuum line.
I had to leave mine on 'cause of the "visual, emissions equipment" inspection, but it is blocked off at the plenum. Haven't noticed any problems (9500 miles).
Old Sep 23, 2005 | 05:50 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
yea it should be vac controled. My car seams to like it hooked up.
Maybe your confusing it with another part?
Old Sep 23, 2005 | 05:59 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I'm pretty sur ethe 3.1s got th edigital/linear egr. I think it's also the same one th e3.4s got.
Old Sep 24, 2005 | 12:09 PM
Its an 86' 2.8 in a Camaro with an auto trans....
Old Sep 24, 2005 | 12:40 PM
V6sucker's Avatar
Engine: blown up
again, if you are willing to deal with the issues arrived from doing so... go for it.
Old Sep 24, 2005 | 12:56 PM
Well I got emissions testing up here in CT so I should Probably leave it on.
Old Sep 26, 2005 | 06:58 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
the ECU will throw a code for the vacume EGR mine does all the time cause the one in my dont work and when ever i check codes the only one i get is the friggin EGR code also mine has a t off of the line from the solenoid to the EGR valve that has a sensor attached to it. the ECU will also look for a drop i exhaust temps at the same time it command EGR if it dont see that it will throw a code. well thats what my book says but it could be wrong. wouldnt be the first time.
Old Sep 26, 2005 | 08:24 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
No that is correct, the ECM will look for small changes when the EGR is commanded, sometimes the ECM is set-up to throw a code for minor glitches, some not. Take the '88 Z24 ECM, the EGR can be completly disconnected for the vehcile and it won't throw a code, but in '90 (which actually uses a different EGR) The Z24 will throw a code if even a small change is detected.
Old Sep 27, 2005 | 02:51 PM
dcm01003's Avatar
Car: Black 89 Camaro RS w/t-tops
Engine: 2.8L (173ci) v6
hey if you end up modifying your middle intake manifold and making a custom upper oneone let me know, I live just outside of UCONN and would like to see what you do with it up close.
Dave
Old Sep 27, 2005 | 03:51 PM
Im making a whole new intake setup. Actual manifold n all as soon as I get some responces on my other post... beleive the topic is HELP!! if yall wanna go check it out.
Kenwood
Sep 11, 2015 12:50 PM
Nick McCardle
Sep 10, 2015 08:36 PM
rjcme
Sep 5, 2015 01:23 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
