Strong smell of gas, car running like crap
Old Sep 23, 2005 | 10:33 PM
dxacer01's Avatar
Car: 89, 87, and 84 Firebirds
Engine: 2.8. 2.8, 350
When ever I stat my car I get a really strong smell of gas and more recently whenever I accelerate, idle or anything else. My car just seems to be running worse and worse. When ever I accelerate I hear a thump in the front in I think its the shocks? Any ideas of what going on or ways to fix it?
Old Sep 23, 2005 | 11:45 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
check fuel line!!! check injectors!!!! and of course try to locate the smell,.,. just follow yer nose.,.,.,.,
Old Sep 24, 2005 | 12:23 AM
Highwind's Avatar
Car: 1988 Firebird
Engine: 305 TBI
Aside from the injectors and fuel lines, you might want to check out the shrader (sp?) valve. On my mom's 3.1, it wouldn't seal from time to time and because the cap was missing, the gas would leak . In case you don't know where it is, look at top of the motor between the rear of the plenum and the distributor (on the fuel rail I believe). The valve might be exposed but should have a cap (silver in apperance). If it's leaking, a cap would be a temporary fix, but you can get the valve through GM. I don't recall the part number but I think you have to get it through a small kit (you can't get the valve alone ).
Another area to look is to check the purge canister (black cylinder shape container located on the opposite side of the battery). Check the hoses running to and from it.
Another area could be somewhere on the tank, where the filler neck attaches to the tank, or that valve that vent's the tank (looks like a white saucer with one line going to it near the tank). I think that vent valve is located near the filler neck mounting point.
As for the "thump", your tranny mount might be fractured or loose.
Old Sep 24, 2005 | 09:49 AM
LT1guy's Avatar
Car: 1987 Trans Am
Pull the top off of your fuel pressure regulator; there is a rubber diaphragm under the cap, and you'll probably find a hole in it. Even the slightest hole here will cause a massive rich condition, as much of the fuel that would normally be forced into the return line is now going into the engine. If you can't find a new diaphragm locally, get a Holley Adjustable fuel pressure regulator for a TPI application; they fit and work fine.
Old Sep 24, 2005 | 04:31 PM
dxacer01's Avatar
not sure if this will help but finaly got the ses light....it gives me codes 32, 34, and 44
Old Sep 24, 2005 | 05:16 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
and you do not own a book to look them up in?
try getting your hands dirty and actually pick some stuff apart and INSPECT the above mentioned things.
Old Sep 24, 2005 | 10:42 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Common sign of a bad cold start injector.
Old Sep 25, 2005 | 01:16 AM
gottfuel's Avatar
hey dxacer01 BINGO! what did i win man! lol j/k yea hey did ya find out what the codes mean?
Oh hey gumby could ya tell us how to fix this problem? i believe your correct but i heard somewhere we can no longer find a replacement part.,,. hopfully i was misinformed but either way tell us what to do bro!
Old Sep 25, 2005 | 02:15 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Thats what they say, you can't get it anymore.
If mine was bad, I would just disable it / block the flow of fuel to it.
No gas, no work.
Old Oct 1, 2005 | 12:10 PM
86BLUEBIRD's Avatar
Car: 86 Firebird 2.8
Engine: 2.8l v-6
Transmission: auto
32=egr i believe
34=MAF
44=Lean
Make sure ur o2 sensor wire has not been charred to ur exhaust pipe.
bryan623
Mar 22, 2021 06:43 PM
9192camaro
16
Feb 3, 2019 12:21 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
