Help!!
Old Sep 27, 2005 | 01:47 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Help!!
What are the wires and such that are plugged into the intake manifold. Thers 2 of them right next to the T-stat. 1986 2.8 V6 Camaro. Making new intake and such so wondering if they are needed. Going to disassemble car now so input would be appreciated greatly. Thanks
Old Sep 27, 2005 | 04:24 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
In for pics.
Old Sep 27, 2005 | 05:22 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Old Sep 27, 2005 | 06:18 PM
If the picture works its the plugs that Im pointing at....
Old Sep 27, 2005 | 06:20 PM
Sorry about the size.... Hope this is better
Old Sep 27, 2005 | 07:16 PM
The_Raven's Avatar
The one with the black connector and black and yelow wires is for the ECU, it is for the coolant temp. Yes it's needed.
The other one, I'm not familar with, none of my vehciles had that. But looks to be a temperature sensing switch or sensor. Probably needed anyway.
Old Sep 27, 2005 | 07:26 PM
So if I made a new intake manifold, how would I go about installing those? Just drill and tap some holes that the coolant runs threw?
Old Sep 27, 2005 | 08:13 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
pull the manifold and see what they hook into, then go from their, the cts will just need a hole drilled and tapped for it, the rest of them you will need to figure it out
Old Sep 28, 2005 | 10:33 AM
bru333's Avatar
Car: 1987 Camaro SC
Old Sep 29, 2005 | 04:24 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
clearly.
Old Sep 29, 2005 | 11:12 AM
Sorry bout that Bru333. Your pics arent working on my screen so I assumed it was the same for everyone.
Old Sep 29, 2005 | 12:09 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
both go to coolent passages. Yes, drill n tap a hole.
Old Sep 29, 2005 | 02:06 PM
Thanks Dale. Helping me out alot on my project.
Old Sep 29, 2005 | 02:44 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
The blue connector is the cold temperature switch to activate the cold start injector I believe. As someone said, it also goes into the coolant.
