question
Old Sep 29, 2005 | 04:00 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
question
i have a 92 firebird with a 3.1 engine auto tranny
i was wondering how to pull codes off the computer.
and what kind of tranny i got.
i looked around on here i seen headers for 2.8 not 3.1 does anyone make them, and pulleys also.
Old Sep 29, 2005 | 05:19 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
pullys, aspracing.com, do not get the alt pully, just the crank.
codes, can be pulled with a paperclip and a haynes manual from local parts store.
tranny, auto=700r4, manual=wct5
the headers will fit a 3.1 if your not in a smog state.
Old Sep 29, 2005 | 05:35 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
so i have a 700R4->T5 tranny,
i have a repair manual, but i can find the thing to pull codes from,. can u tell me where is it at please, thanks chris
so u are talking about this pulley
88-95 2.8, 3.1, 3.4 25% Crank 900 RPM ASP541800
$64.95
do u need to get a smaller belt
Old Sep 29, 2005 | 06:51 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Yes you will need a smaller belt, when you get your crank pulley it will give you a part number for the belt for your specific car year.
Old Sep 29, 2005 | 07:16 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
engine question
when my engine is cold, its got full power,
then my engine is hot. i lost power,
i change the cap, rotor, plugs and wires.
and my engine light is on, and im trying to figure out how to pull codes and see why the engine light is on, can someone help me chris thanks
Old Sep 30, 2005 | 10:06 AM
Dale's Avatar
Engine: 350 S-TPI
you short out termainal a-b, and count your check engine light flashes. The repair manual tells how.
you have a 700r4, I missed that you said auto.
correct pully, and whatever belt they list, get one half an inch shorter, mine slipped.
engine runs in default mode when its not warmed up, as well as its generally sucking colder air. So it will feel more powerful then.
May have something wrong, but doubt full. Check all your engine sensors.. ECT, O2, TPS,
Old Sep 30, 2005 | 11:33 AM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
thanks so much, do u have a pic of termainal a-b
or where it is
Old Sep 30, 2005 | 12:10 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
or where it is
the OBD terminal by the fuse box...
Old Sep 30, 2005 | 12:25 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
under the dash on the driver side right
Old Sep 30, 2005 | 12:30 PM
Dale's Avatar
Engine: 350 S-TPI
yea, close enough. Prob something you could hit your knees on?
I belive a-b is the upper right two.
jump it with paper clip.
turn car to "radio on", or just the cick past.
then count the blinks.
Will start with blink, short pause, blink blink, long pause=code 12
will repeat that 3 times
then on to next code
it all should be in that repair manual.
Old Sep 30, 2005 | 01:26 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
sory if im bothering u, i just put 2 paper clips in ,
the paper clips are touching or not tounhing, last question
Old Sep 30, 2005 | 03:02 PM
Dale's Avatar
Engine: 350 S-TPI
bend it into a u shape.
Old Sep 30, 2005 | 11:26 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
why does everyone say not to run the alt (ud) pulley? i'm running it and the crank pulley, i have stereo stuff, and i have no problems with it, at all.
Old Oct 1, 2005 | 11:04 AM
V6sucker's Avatar
Engine: blown up
it can cause low voltage.
the 90-92's have a higher amp alt I beleive, so those years are not as problematic using it.
Hell, I just went with a high output alt on my 92 and the car just flat out ran better... all the power I could ever need, nice bright lights and all. 140 amp solves everything.
Old Oct 1, 2005 | 11:08 AM
Car: 91 Camaro
ok. cause i never do have any problems with it.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
