Racing questions
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Racing questions
When i drag race which will be the fastest, going in drive, over drive or 1 to 2 to d. When im at the burnout box should i powerbrake and can a v6 pull up some smoke? Also can the little 3.1 spin tires at wot?
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
meh, you're automagic... a 4k sidestep sends my rear tire blazin'
If you're heading to the dragstrip, try it different ways, and see what works best on your car
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Yes a 3.1 can spin tire if your front brakes hold decent. Don't light them up forever....JUST enough to heat em up a tad. Dont wanna get street tires too hot or else they act funky. Usually 1-2-D works best, but it depends on your trans shiftpoints. 3.1's are lower-end motors...dont over-rev it, you'll go nowhere. I wouldnt shift any higher than 5500 rpms, if I remember the behavior of mine...
Also, avoid the water trap.
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
avoid water like nixon said. i never really do much of a burnout, even. i just "dry hop" it a time or two. it'll clean the tires off if they're dirty. i've never really needed any real burnouts or anything. also, i'd rev it to about 1k when you're getting ready to launch (with it in gear and left foot on brake).
your a fairly stock automatic I can't see you lighting them up enough to really have traction issues.... unless you drive through the water box.
so stay from the box and just launch the car I doubt your going to really break traction that bad
