coil pack
Old Oct 12, 2005 | 09:13 AM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
coil pack
how do i get the coil pack off, i want to replace it with a new one
Old Oct 12, 2005 | 09:57 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
using any combo of the following:
dremel tool w/cut off wheel
mallet & chisel
punch
Old Oct 12, 2005 | 10:00 AM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
mallet & chisel
punch
Oh man, the third gen 2.8s use that rivited coil bracket?
Old Oct 12, 2005 | 10:33 AM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i have a 3.1 is it the same as 2.8
Old Oct 12, 2005 | 07:02 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i used a drill
Old Oct 13, 2005 | 01:12 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
I used pretty much the same approach as 85 bird. Just ground off the heads of the rivits with a dremel, punched the rest out with a small screwdriver, and then used some self tapping screws to put it back on with. Oh,and you use the screws, be sure to put som caps over the pointed ends sticking out, nothing like and operating temperature screw point to wake you up.
Max
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Zell1luk
Sep 29, 2015 10:36 AM
