reverse lights?
Old Oct 12, 2005 | 07:26 PM
89firebirdguy05's Avatar
Car: Firebird
Engine: 2.8
Transmission: 5spd
reverse lights?
Hey i got a 5spd 2.8 liter..and my reverse lights stopped working. Do you think it can be both bulbs or something else? I really doubt both bulbs burnt out but i need to fix it so i can get it inspected.. any input woudl be greatly appreciated! thanks
Old Oct 12, 2005 | 08:53 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
sensor/trigger in the left side of the trans. Cost about 10 bux.
When you jack the car up, have the left higher then the right. Will be less likely to loose some fluid.
Check fuse(s) also.
Then I would suspect bulbs or wiring.
Old Oct 12, 2005 | 11:41 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
get a circuit tester & check. ALso grab some speaker wire & test out the bulbs, or temp swap w/working turn/brakelights.
Old Oct 13, 2005 | 01:31 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
It's probably the backup switch... it happens.. not big deal to replace.. and does not cost a whole lot a t all. 10$ or so
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jetmeck
Sep 4, 2015 12:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
