Miss Fire
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Miss Fire
My number 3 and 5 sparkplugs are arcing between eachother by the base i thought it was bad wires changed those it is still doing it. Could it be one of them is a bad plug and causing an arc? Need help.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Where it meets the head? WTF?
Bad plugs?
Motor not grounded properly?
Make sure the cap is good and clean.
Bad plugs?
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
I didn't realize it was at the plugs. Possible a piece of metal between the 2. Pull the plugs and double check. May not be that big but even a small piece would do that.
I had my g/f pick up new plugs tongiht i am going to replace them and see what happens my 40 mile drive to school sucked i have to wait until i am out of class.
Found it the #5 plug was bad the center electrode was gone the prawn was melted and the plug was destroyed put a new one in runs great.
